7"3' vs 7"6" save any gas mileage???
Last activity 2013-02-27 11:53 PM
8 replies, 5066 views
greyghost
Reg. Jan 2013
Posted 2013-02-27 5:52 PM (#150219)
Subject: 7"3' vs 7"6" save any gas mileage???
Hi everyone.Trailering shopping. Looking for small LQ and I originally wanted 7"6' basically b/c I want lots of headroom to sit in bed as an alternate to sitting on couch (or place to sit if I take a friend) to hang in bed and watch TC, laptop, etc. I can JUST sit in aq 7"3' with my head hitting the top in a seated position.The trailer available locally that I'm considering is 7"3' so I'm considering it - and wondering if I'm going to save gas mileage pulling it without hitting the wind resistance?I have a Dodge Ram 2500 Diesel 2006 5.7 cummings and it gets great mileage to begin with. Not sure if it's really going to make a difference. But if it did - might sway me waiting to order just another few inches.Thanks.
greyghost
Reg. Jan 2013
Posted 2013-02-27 5:52 PM (#150220 - in reply to #150219)
Subject: RE: 7"3' vs 7"6" save any gas mileage???
Oh, I mean in the GN.
Javanewt
Reg. Apr 2011
Posted 2013-02-27 5:58 PM (#150221 - in reply to #150219)
This is an interesting question. However, can't the gooseneck height vary regardless of the height of the horse area? Wouldn't you need to check that separately? (I actually don't know, but from pictures and trailers I've seen, that seems to be the case.)
greyghost
Reg. Jan 2013
Posted 2013-02-27 6:01 PM (#150223 - in reply to #150219)
I think it can - but it doesn't seem to be standard. The one I'm looking at is only 7"3'
Posted 2013-02-27 6:45 PM (#150226 - in reply to #150219)
  Quote... 7"3' vs 7"6" save any gas mileage???
   NO!
greyghost
Reg. Jan 2013
Posted 2013-02-27 6:48 PM (#150228 - in reply to #150219)
Poop. Wrong answer, dave. :)
Posted 2013-02-27 8:48 PM (#150234 - in reply to #150219)
There are so many other factors to consider beside just the trailer height and width.
Open drop windows, awning, hay rack, flat nose vs a V-nose will all have some effect.
I think that once you get up into that size & weight of trailer the difference for each of the above is pretty small.
Posted 2013-02-27 10:18 PM (#150237 - in reply to #150219)
There is an aerodynamic advantage to a smaller frontal area, but the differences between your two examples, would be so small as to be negligible. As PH mentioned, many other items can affect your mileage, some more so than a trailer height difference.
Buy the trailer that will be the most comfortable for you. Not only will you enjoy it more, but the resale value of a taller trailer exceeds that of a shorter one.
Posted 2013-02-27 11:53 PM (#150239 - in reply to #150219)
”The things that cause drag are those areas that have an abrupt change in flow,” says Volvo’s Ed Saxman. “The biggest thing is the top of the trailer. We learned that in 1983 when we were the first manufacturer to put a fairing on the truck roof.” “If there’s nothing on the roof of the cab to throw air over the trailer, the air is like hitting a billboard,” says Tom Davis, Mack’s highway product manager. - See more at: http://www.overdriveonline.com/winds-of-change/?pg=2#sthash.XSIgFa7...
