Duramax
Last activity 2013-03-01 10:08 PM
10 replies, 6774 views
Gone
Posted 2013-02-27 5:31 AM (#150199)
Subject: Duramax
10002525
Does anybody know any common tranny leaks on a 2005 Chevy duramax? My demon truck all of a sudden started leaking pretty good yesterday. Hubby thinks it might be a seal, going to check it today. Wondering how much this bill is going to be.
captclank
Posted 2013-02-27 6:05 AM (#150200 - in reply to #150199)
Subject: RE: Duramax
You can do research at www.dieselplace.com for your problem. This website has helped me MANY times with my Duramax. You can look in the transmission section. Good Luck
MrSteve
Reg. Jul 2012
Posted 2013-02-27 12:48 PM (#150209 - in reply to #150199)
What cap said... And I would check the trans cooler lines and also the spin on filter.
To add, make sure it isn't the hydro boost for the power brakes.
Edited by MrSteve 2013-02-27 12:50 PM
TKLeather
Reg. Feb 2013
Posted 2013-02-27 1:02 PM (#150210 - in reply to #150199)
I have the 8.1 Liter version with the same trans.  I have replaced cooler lines, pan gasket, and the seal where the control shaft go through the main housing.  Still have some seeps, I cant find em all but I suppose after 300k its allowed to have a few wounds that wont heal
Posted 2013-02-27 1:23 PM (#150212 - in reply to #150199)
Originally written by Gone on 2013-02-27 5:31 AM
The biggest failure point tends to be where the transmission lines attach to the transmission cooler.
sinful
Posted 2013-02-28 5:59 AM (#150244 - in reply to #150199)
Paul is right. I had to replace mine tranny lines at 53,000 miles. Dealer wouldn't stand behind it because it was out of warranty age wise. Its not a big job if you are mechanically capable of working on it yourself. Dealer wanted $600 to do mine. Bought the tranny lines over the internet for $175 and did the job myself with help from a mechanic friend.
genebob
Reg. Nov 2007
Posted 2013-02-28 12:01 PM (#150251 - in reply to #150199)
Yep, probably tranny lines. Replaced mine @ 75,000 miles on my 08. Had my mechanic do it because it is a lot easier to do on a hoist and he's done many others recently. Cost me about $300, but he has a low hourly rate.
Edited by genebob 2013-02-28 12:03 PM
Gone
Posted 2013-03-01 5:54 AM (#150267 - in reply to #150199)
10002525
It ended up being two bolts and correct me if I am wrong in saying this but there were two plugs/seals on or buy the pan...? Anyhoo, I should be getting it back today and I will be taking my original parts back as always. They told me my fuel filter light is on...um I know and NO we will take care of it.....$940.00 later....
Edited by Gone 2013-03-01 5:57 AM
MrSteve
Reg. Jul 2012
Posted 2013-03-01 8:19 AM (#150270 - in reply to #150199)
Fuel filter light... More then likely needs to be drained of water, not hard to do. Check your owners manual on how to do it, BUT I would also change the filter... I hope that figure you just gave wasn't for fixing the leak and or fuel filter light. If so I think we all would like to know what description of work was quoted.
Gone
Posted 2013-03-01 6:22 PM (#150286 - in reply to #150199)
10002525
Torque converter seals and two bolt seals. They get you on labor...Oh well, couldn't fix it this time ourselves. It is what it is.
Edited by Gone 2013-03-01 6:23 PM
Posted 2013-03-01 10:08 PM (#150290 - in reply to #150286)
Originally written by Gone on 2013-03-01 6:22 PMTorque converter seals and two bolt seals. They get you on labor...Oh well, couldn't fix it this time ourselves. It is what it is.
Well, glad to see it was resolved...if you do NOT want to revisit this issue, the next time at the transmission cooler line connections...AVOID LONG IDLING PERIODS...
Edited by PaulChristenson 2013-03-01 10:10 PM
