Brake controller wiring issue....any insight??
Last activity 2013-01-14 12:36 AM
4 replies, 4395 views
AZgrulla
Reg. Jan 2009
Posted 2013-01-13 8:10 PM (#149309)
Subject: Brake controller wiring issue....any insight??
Truck: 1999 Chevy C3500 DRW
Brake Controller: Tekonsha Prodigy
Issue: this was a self install job. So, we installed the controller per the directions...truck is not 'pre-wired'. Hauled both trailers for a time with no issues with controller until on one trip it locked up. Had to unplug it from the pedal. It melted the fuse and the wire that runs from the pedal to the controller. Controller does work.
We can only use the 'hand slide' control.
Posted 2013-01-13 9:59 PM (#149312 - in reply to #149309)
Subject: RE: Brake controller wiring issue....any insight??
My guess would be something that is grounded & it shouldn't be. Trace the wire, see where it's getting pinched or grounded out & replace it. It could have a bad connection at the other end causing the issues too.
conner
Reg. Feb 2010
Posted 2013-01-13 11:01 PM (#149316 - in reply to #149309)
There is a wire, maybe the red one, coming out of the brake control that goes to the cold side of the stop light switch. Back in those model years you had to go under the dash, above the steering column to a large loom of wires. In that loom there was about 7 white wires and you need to find the one white wire that goes hot when you press the brake pedal. That loom was about the size of a quarter. I put brake controls in these Chevrolet's for for years and this was the hardest one out there. No room to work, laying upside down with a test light probing white wires while pushing the brake pedal with your elbow. Back in the mid 90's Tekonsha furnished directions explaining this exact procedure when installing a 9030. Lots of luck.
Posted 2013-01-13 11:42 PM (#149317 - in reply to #149312)
Originally written by PaulChristenson on 2013-01-13 6:59 PM
This ... it worked before. Something changed.  Test the controller with 12 volts after disconnecting the brake pedal wire from the controller.  This simulates the brake switch closing.  If the controller doesn't work in this test, it is bad.
BartBarrera
Reg. Jan 2013
Posted 2013-01-14 12:36 AM (#149318 - in reply to #149309)
My guess would be something that is grounded & it shouldn't be. _________________________Buy dvd movies online directly from our websites instead of going outside!
