Can pick up pull this trailer
Last activity 2013-01-11 6:55 AM
9 replies, 7123 views
jpzoejo
Reg. Jan 2013
Posted 2013-01-09 11:35 PM (#149227)
Subject: Can pick up pull this trailer
We have a gas 1999 F250 V10 single axle short box pickup with a new fairly new transmission.The question is, can this pick up pull a 38 foot long, 8 foot wide, 3 horse living quarter trailer with a slide out, steel frame, 17800 pounds? We will only be hauling 2 horses.Anyone have any idea?
Posted 2013-01-10 12:54 AM (#149229 - in reply to #149227)
Subject: RE: Can pick up pull this trailer
no
Posted 2013-01-10 1:23 AM (#149230 - in reply to #149227)
A more complete answer is check your Gross Combined Vehicle Weight Rating.  It'll be in your manual.  You'll have to look for your engine, rear axle, etc.
Add the trailer weight to the truck weight = GCVWR
But for 17,800 pound trailer ... Not likely.
Posted 2013-01-10 1:25 AM (#149231 - in reply to #149227)
Also ... Youe have to keep from overloading your truck's axles.
Again... not likely with that trailer.
RTSmith
Posted 2013-01-10 8:36 AM (#149235 - in reply to #149227)
Is the 17,800 a trailer weight, or the GVWR? Sounds heavy for the empty trailer be a few tons.
rose
Posted 2013-01-10 9:47 AM (#149237 - in reply to #149227)
10005001002525
Could possibly pull the trailer, but could not stop it. It would not be safe. jmho
trot-on
Reg. Dec 2009
Posted 2013-01-10 1:53 PM (#149244 - in reply to #149227)
I'd guess that truck is rated at the most to pull a combined load of 20,000 pounds. Just guessing by age. That is a big trailer......I agree, bigger truck, or smaller trailer needed
Posted 2013-01-10 5:16 PM (#149249 - in reply to #149227)
From the 1999 trailer life towing guide... maximum trailer weights.. I have a 2001 GM 3500 with tha 8.1 gas engine, max. trailer weight is something like 15000#.
F-250 SD 6.8 V-10 10,000a,d/e
F-250 SD 6.8 V-10 11,600a,d,g
F-250 SD 6.8 V-10 14,600a,g,o
F-250 4WD SD 6.8 V-10 11,100a,d,g
F-250 4WD SD 6.8 V-10 14,100a,e,g
F-250 SuperCab SD 6.8 V-10 11,300a,d,g
F-250 SuperCab SD 6.8 V-10 14,300a,g,o
F-250 SuperCab 4WD SD 6.8 V-10 10,800a,d,g
F-250 SuperCab 4WD SD 6.8 V-10 13,800a,g,o
F-250 crew cab SD 6.8 V-10 11,000a,d,g
F-250 crew cab SD 6.8 V-10 14,000a,g,o
F-250 crew cab 4WD SD 6.8 V-10 10,500a,d,g
Code break down, match your truck...
*SRW = single rear wheels. DRW = dual rear wheels
**TD = turbodiesel
***SD = Super Duty
aRequires automatic transmission and towing package.
bRequires 3.31:1 axle ratio.
cRequires 3.55:1 axle ratio.
dRequires 3.73:1 axle ratio.
eRequires 3.98/4.09/4.10:1 axle ratio.
fManual transmission.
gFifth-wheel towing.
hAutomatic transmission.
iMust be equipped with heavy-duty towing package.
jRequires automatic transmission cooler.
kRequires 16-inch rims.
lAutomatic rated slightly lower.
mRequires 17-inch wheel option.
nRequires 3.27:1 axle ratio.
oRequires 4.30:1 axle ratio.
pRequires 4.88:1 axle ratio.
qRequires 5.38:1 axle ratio.
rNGV = natural gas fueled vehicle.
http://www.trailerlife.com/wp-content/uploads/2012/01/Trailer-Life-Towing-Guide-1999.pdf
Edited by retento 2013-01-10 5:18 PM
Posted 2013-01-10 10:49 PM (#149255 - in reply to #149227)
Originally written by jpzoejo on 2013-01-09 11:35 PM
NO
cajunmuleman
Reg. Oct 2011
Posted 2013-01-11 6:55 AM (#149258 - in reply to #149227)
Don't try it
