Plug in connection to LQ trailer keeps tripping at plugin
Last activity 2012-12-06 4:58 PM
6 replies, 5747 views
MsZoey
Reg. Oct 2004
Posted 2012-11-19 1:16 PM (#148445)
Subject: Plug in connection to LQ trailer keeps tripping at plugin
I have a trailer with a 30 amp plug in, push in twist has a ring to screw to hold in place. I had a problem at the last show when I connected to electrical box. Every time I plugged into the box it tripped the breaker. Electrician looked at, a wire had came loose from one of the prongs on the connector at my trailer. His comments were these types are a piece of junk. Went to a show this past weekend, it has happened again. Anyone have suggestions, what type you have, etc.. open to any suggestions,, this is a real pain, to not know when you are going to have electricity or not...
dkhunter04
Reg. Oct 2008
Posted 2012-11-19 4:40 PM (#148451 - in reply to #148445)
Subject: RE: Plug in connection to LQ trailer keeps tripping at plugin
Did it trip the breaker in the trailer or on the line you were trying to plug into?
Posted 2012-11-19 6:48 PM (#148456 - in reply to #148445)
I'm not sure what you are talking about with a screw ring on a 30 amp plug.
This is a standard 30 amp twist plug.
http://www.toolking.com/cooper-wiring-l530p-30-amp-twistlock-ground-3-wire-plug?CAWELAID=1410718127&catargetid=1436452153&cagpspn=pla&gclid=COyIjeao3LMCFeGDQgodORAAgg
Most RV's just use a standard 3 prog plug that doesn't twist
http://www.rvwholesalers.com/catalog/15ft-30amp-rv-ext-cord-ezee-gr-19-0548.html?gclid=CKaJ3qap3LMCFeGDQgodORAAgg
Wrangler48
Reg. Jul 2010
Posted 2012-11-19 7:01 PM (#148458 - in reply to #148456)
Hi, I believe this is the type of connector described.
http://images.sundownerparts.com/www.sundownerparts.com/resized_IMG...
MsZoey
Reg. Oct 2004
Posted 2012-12-06 1:09 PM (#148763 - in reply to #148451)
tripping at the box where I was plugging into.
MsZoey
Reg. Oct 2004
Posted 2012-12-06 1:19 PM (#148764 - in reply to #148458)
Yes this is the type of plug, the connection on the trailer is a female end. white box with a trap door you lift to plug into.
Posted 2012-12-06 4:58 PM (#148773 - in reply to #148445)
You have a short...my recommendation is a new landline which is the easiest replacement...if that doesn't work the next step is to replace the outlet on the side of the trailer
Edited by PaulChristenson 2012-12-06 5:00 PM
