How hard is it to change your sewage tanks on trailer?
Last activity 2012-10-08 5:26 AM
2 replies, 3904 views
run4drums
Reg. Oct 2012
Posted 2012-10-07 5:50 PM (#147491)
Subject: How hard is it to change your sewage tanks on trailer?
 Besides the straps and screws what else is there? Is there a clamp that hold the line in place for the sewage to come down. Thinking of doing myself. The tanks havent been used in over a yr and was cleaned out after the tanks were broken.
301duster
Reg. Jan 2009
Posted 2012-10-07 7:09 PM (#147492 - in reply to #147491)
Subject: RE: How hard is it to change your sewage tanks on trailer?
The toilet has a screw in flange that you need to deal with but when I did mine I just broke it to remove it. Then had to cut and glue the new one into the correct position and I also got a new flange for the top as that was also cracked. Vent pipes and grey drains were all slip in rubber grommets. Just cut the holes right and slip them on. This was on an older Featherlite with factory LQ. Few hours job to measure it and do it right, I was able to get exact replacement tanks.
run4drums
Reg. Oct 2012
Posted 2012-10-08 5:26 AM (#147498 - in reply to #147491)
Ok awesome! Thanks so much!
