How much to get bearings packed?
Last activity 2012-10-02 9:48 PM
9 replies, 6865 views
blackcows
Posted 2012-10-01 3:22 PM (#147362)
Subject: How much to get bearings packed?
100100100100252525
What do you pay to get trailer bearings packed?
horsey1
Reg. Dec 2004
Posted 2012-10-01 4:16 PM (#147365 - in reply to #147362)
Subject: RE: How much to get bearings packed?
About $220 last time. Included getting brakes checked & adjusted.
Posted 2012-10-01 5:08 PM (#147368 - in reply to #147362)
$24.00  ... (4) $5 seals and (4) $1 tang washers
Plus a glob of grease and a couple of hours of my time.  Most of the effort is getting off this computer.
This is me ...  http://www.mrtrailer.com/hosspullerbrakes.pdf
jackbrat
Posted 2012-10-02 12:44 AM (#147376 - in reply to #147362)
500100
I guess it depends where u live cause it cost me over $300- here. Northern Cali
Posted 2012-10-02 12:57 AM (#147377 - in reply to #147368)
Originally written by hosspuller on 2012-10-01 5:08 PM
You forgot the cost of the gloves and the soap to clean up after...
Kay
Posted 2012-10-02 8:10 AM (#147384 - in reply to #147362)
50025
Assuming you don't want the mess on you and your surroundings, the cost for someone else to do it will vary a bit depending on where you are.  Here in the midwest we charge a flat rate of $25.00 per wheel for 7000# axles and smaller, plus new seals at $3 to $4 each.  This is assuming that the bearings are good.  New bearings and races will average $15 to $25 per wheel, depending on the axle size, plus $5 per wheel to drive the old races out and the new races in.
trot-on
Reg. Dec 2009
Posted 2012-10-02 9:27 AM (#147386 - in reply to #147362)
Last quote I got here in TX was $200 for all four.
Now, I had to work on one on the road once, and found that it was not as tough as I expected. Very messy, and it seemed the trick may be getting them the right tightness/tension.
I may do my own next time
Posted 2012-10-02 10:55 AM (#147387 - in reply to #147362)
I just did mine saturday. A couple tubes of grease and 3 hours of my time.
Posted 2012-10-02 10:59 AM (#147388 - in reply to #147362)
Jeepers !!! Horse people afraid of a little mess !! never heard of such outside of a show ring.   Must be show people   LOL
Pair of nitril gloves, lots of rags and a can of solvent make for easy cleanup of parts and tools.  Pull the gloves off, turning them inside out and I don't even need soap later.  I get more grease on me from the hitch ball than this job.
Edited by hosspuller 2012-10-02 11:00 AM
trot-on
Reg. Dec 2009
Posted 2012-10-02 9:48 PM (#147397 - in reply to #147362)
But, you get them to tight, like the mechanic did whom I did paid to do them, and you can have some serious issues. I'm glad I did my walk around while getting fuel, feeling each hub, and found one super hot. Thus, learning how to take it apart and loosen a tad.
