Metal on Metal Mess
Last activity 2012-10-02 4:43 AM
6 replies, 5481 views
blackcows
Posted 2012-09-30 8:18 PM (#147344)
Subject: Metal on Metal Mess
100100100100252525
The rear doors on my horse trailer have a metal strap (not sure exactly what to call it) that goes over the top of a metal piece on the door to keep it closed.
It looks like this...
http://vehicles.oodle.com/detail/lq-3h-exiss-aluminum/3177399333-grants-pass-or/?cm_mmc=OODLE_PREVIEW-_-www-_-NA-_-NA
There is always a black grease, film, mess that comes from these pieces of metal.  I have always assumed that the previous owner of my trailer used too much grease and eventually it would work it's way out.  Today we were at a horse show and had time to kill so I got out some cleaner and started to try and wipe some of the black away.  A lady next to us came over and started talking to me, asked what I was using because they had the same issue.  Her husband came over and we go to talking and he said he thinks the black is a result of the metal rubbing togeather.  Could this be the case?  If so any idea how to fix it?  It makes a mess on your hand when you open the doors, it gets on the doors, it's just a mess.
gonzo1066
Reg. Oct 2010
Posted 2012-09-30 10:33 PM (#147348 - in reply to #147344)
Subject: RE: Metal on Metal Mess
I would assume that black you are seeing is in fact caused by the aluminum rubbing against the other aluminum.  This causes aluminum dust that turns black in the presence of oxygen..    The only way I can think of preventing this is by having a rubber or HMVW strip installed on one of the surfaces to prevent metal to metal contact.
blackcows
Posted 2012-10-01 3:13 PM (#147359 - in reply to #147348)
100100100100252525
Originally written by gonzo1066 on 2012-09-30 10:33 PM
blackcows
Posted 2012-10-01 3:17 PM (#147360 - in reply to #147348)
100100100100252525
Gonzo,
Thanks for the reply, I had always thought it was grease but I am sure you are correct as it is aluminum rubbing against aluminum.  The black dust most likely picks up moisture and becomes the black mess I am seeing.  What is HMVW?  I tried to search but only found informaton on a rock band :)  Do you think there would be anything available at Menards or Lowes that I could use?  I know they have lots of foam tape with a sticky side but I am sure that would not last very long.
Posted 2012-10-01 4:55 PM (#147367 - in reply to #147344)
Cheap solution... Get a Cool-whip container lid or a 5 gallon bucket.  This is made of either polypropylene or polyethylene.  It's a slippery plastic and will keep the two metal pieces from rubbing.  Cut a strip and fasten it to the "strap"  You don't want a piece too thick or it will stress the door closure.  Double stick tape will work if you rough the plastic with sandpaper.  Some glues might work too
A previous post mentioned UHMW.  This is Ultra High Molecular Weight polyethylene.   This is nice stuff but not needed in this application.  Although it is available as an adhesive backed tape.
blackcows
Posted 2012-10-02 4:43 AM (#147380 - in reply to #147367)
100100100100252525
Originally written by hosspuller on 2012-10-01 4:55 PM
I think I am too much of a neat freak to use something I cut myself...I think I will try the hardware store and see if I can find something.
blackcows
Posted 2012-10-02 4:43 AM (#147381 - in reply to #147367)
100100100100252525
