Measuring Safety Chains
Last activity 2012-09-01 8:21 AM
5 replies, 5345 views
OakGroveRider
Reg. Jul 2012
Posted 2012-08-30 8:51 PM (#146731)
Subject: Measuring Safety Chains
Hi-
I just bought a gn two horse. Because of my short-bed Dodge 1500, I bought a 16" popup gn extension. I LOVE IT!!! It make turning the trailer so easy, and no worries about hitting the cab.
BUT... the safety chain that runs through a large cylinder welded on to the back of my coupler, which fit the last owner's truck no problem, does not fit for my truck b/c of the extra length on the extension.
I do not know how long my safety chains should be. I know it should be short enough to stop the trailer from running into the back of the cab- or out of the truck bed- if there is an accident, and that there has to be just enough slack to turn without catching... but how do I measure for that? Is there a formula- or a rule of thumb that folks use? Am I just over thinking it?
I sure want to be safe. I know to use chain and hooks that are above my trailers GVWR rating- but the length is driving me crazy- er. :-)
I haven't found anything online or on RV forums- so I am hoping the good folks here at HTW can help.
Thanks!
Posted 2012-08-30 10:10 PM (#146734 - in reply to #146731)
Subject: RE: Measuring Safety Chains
The chain length should permit a 90-degree turn in either direction. This should be the maximum chain length allowed for the safety chains...that being said...you'll probably need to have a couple of links extra on the chain to fit other trucks configurations...
OakGroveRider
Reg. Jul 2012
Posted 2012-08-31 9:16 PM (#146741 - in reply to #146731)
Thanks- that's perfect. It was really easy to go out and get that measurement.
Now- here's another question...
My trailer is a 1999 steel Adam. It has a welded metal tube on the back of the coupler, such that the past owner used one continuous chain that went through the tube, around the coupler and then to the truck bed. Do I need to use two separate chains and cross them behind the coupler, or is the single chain that runs behind the coupler and connects to the two u bolts in my popup turnover ball safe enough? One friend was afraid that the single chain would allow too much play in an accident situation...
And (sorry, this will make it two more questions) my chain that came from the old owner is rated at 5700 lb., but the trailer has a GVWR of 7000… that seems like the chain might be too light for the trailer. Do I use GVWR or tongue weight when determining how strong the chain has to be?
Posted 2012-08-31 11:54 PM (#146742 - in reply to #146731)
The strength rating of each length of safety chain or its equivalent and its attachments shall be equal to or exceed in minimum breaking force the GVWR of the trailer.
So if you have a 10,000 pound trailer each of two chains has to have a breaking strength of 10,000 pounds.
Posted 2012-09-01 12:15 AM (#146743 - in reply to #146731)
And the safety chains need to be secured to the trailer...I don't think your system will pass muster...but have a local DOT LEO look at it...Here are the safety chain rules by state... http://www.towingworld.com/articles/TowingLaws.htm
Edited by PaulChristenson 2012-09-01 12:16 AM
OakGroveRider
Reg. Jul 2012
Posted 2012-09-01 8:21 AM (#146745 - in reply to #146731)
Thanks again- this is exactly the information I was questioning.
I appreciate your time.
