A late 80sTrailer?
Last activity 2012-08-22 5:27 AM
4 replies, 4494 views
morrisranchtx
Reg. May 2012
Posted 2012-08-18 8:57 PM (#146434)
Subject: A late 80sTrailer?
I am interested in buying a 4 H steel frame trailer with an aluminum skin. Small weekend package. It seems to be in great repair. What issues should I be concerned about with an older trailer like this? The seller is asking 8K for the trailer.
Thanks!
Posted 2012-08-18 10:44 PM (#146437 - in reply to #146434)
Subject: RE: A late 80sTrailer?
The aluminum skin will usually look to be in good repair. The issue is the condition of a 20 year old steel frame, and how well the flooring is holding up. These areas should be especially inspected for rust, rot and damage. Look around the edges of the aluminum skin, where it is affixed to the frame. If you see any greyish or white powder, open holes or pits, walk away and look for another trailer.
Check every hinge, latch and door fit. Purchasing body repair parts for some older trailers can be difficult.
Brakes and bearings on that age of a trailer, should have been replaced at least once by now. If they haven't recently been upgraded, you can expect to have them replaced. Tire condition is important, and depending on the axle weight and tire size, replacements can be expensive.
Most LQ components are readily available, and can be individually obtained from many sources. Check them all for proper opperation. You may find the cabinet doors have well worn hinges and latches. They can easily be repaired as a DIY project.
BigT
Posted 2012-08-19 12:29 AM (#146439 - in reply to #146434)
If it is a Trail-et, I would look where the walls meet the floor, Trail-et used a very thin piece of steel at this point. Look into the wheel wells and under the trailer at the support angle iron for the floor. The supports could rust away from the sides, causing the walls to separate from the floor. If only they would of used 1/4" angle iron, there would be no problem.
morrisranchtx
Reg. May 2012
Posted 2012-08-19 8:48 AM (#146445 - in reply to #146434)
The trailers maker is WW. It was the top of the line rig they made back then. I will inspect those areas. Thanks!
laira
Reg. Jun 2012
Posted 2012-08-22 5:27 AM (#146517 - in reply to #146434)
I am not getting for 80s trailers would you describe??
