2012 Toyota Tundra - 5.7L V8 4WD
Last activity 2012-08-07 10:27 AM
9 replies, 7566 views
barstow
Reg. Feb 2007
Posted 2012-08-05 7:07 AM (#146077)
Subject: 2012 Toyota Tundra - 5.7L V8 4WD
I am looking to replace my 2007 Chevy Silverado I have replaced the front left wheel bearing SIX times in the last two years. Three different mechanics can't tell me why it's blowing through these wheel bearings. I am sick of buying new tires and worried I am going to be stuck somewhere with a trailer and horses... not going GM again... also I am not interested in the F150 because I can't afford the crew cab, and I hate those suicide back doors on the extended cabs
I am considering a 2012 Toyota Tundra with the big 5.7L 381HP engine, rated to haul 10K#. (100% USA built) I have a 2008 Trail-et Westwind 2-horse GN, I believe the empty weight is in the vicinity of 4500#. Pros? cons? My husband insists I need the HD off-road rear end. Yes? A waste of $$? I do not do any volunteer off-roading.
Thanks for your valuable input!
kentuckyrain
Reg. Apr 2008
Posted 2012-08-05 9:06 AM (#146080 - in reply to #146077)
Subject: RE: 2012 Toyota Tundra - 5.7L V8 4WD
I believe you will find the F150 less expensive than the Tundra. In any case, the Tundra should do the job for you.
RidnClyde
Reg. Jun 2012
Posted 2012-08-05 8:59 PM (#146111 - in reply to #146077)
I pulled a borrowed basic 3H GN with my 2011 Tundra double-cab before ordering a new 2H that I plan to put a weekend package in to.  Tundra's do a great job with ~24' trailer's.  I had a Roadmaster Active Suspension put in to help get me to 2000# payload but that was because I had 4WD (reduces payload) and wanted to support the weekender stuff.
The below threads have a lot of Tundra feedback in them.
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=17119
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=16925
Edited by RidnClyde 2012-08-05 9:00 PM
Posted 2012-08-05 10:39 PM (#146115 - in reply to #146077)
1000500100100100252525
I tow a stock  gooseneck trailer with my draft horse in it and have no problems with it you should do fine
barstow
Reg. Feb 2007
Posted 2012-08-06 4:48 AM (#146123 - in reply to #146077)
Thanks for the input, everyone. I checked out the other threads and the link to the Toyota towing forum. Great information. One of the options that I can have is swaybars. Stupid, greenie question: Will sway bar help with a gooseneck or are they just used with a BP?
Posted 2012-08-06 6:47 AM (#146126 - in reply to #146077)
You won't need them with a GN trailer
barstow
Reg. Feb 2007
Posted 2012-08-06 8:03 AM (#146128 - in reply to #146077)
Thanks~
Edited by barstow 2012-08-06 8:04 AM
adeberti
Reg. May 2007
Posted 2012-08-06 12:15 PM (#146132 - in reply to #146077)
You should be fine, but make sure that the pin weight of the trailer doesn't "legally" overload the truck.
Posted 2012-08-07 12:52 AM (#146154 - in reply to #146077)
Originally written by barstow on 2012-08-05 7:07 AM
What kind of loads are you hauling and at what speeds?Since those bearings cannot be lubed, if you get them overly hot, they'll fail.
ridingarocky
Reg. Aug 2008
Posted 2012-08-07 10:27 AM (#146162 - in reply to #146077)
500100252525
I have a 2010 Tundra. I recently, after a long search, bought a 1998 Elite 2 horse gooseneck. Empty wt @ 3900 lbs. I have not pulled it much as yet..I don't trailer here in the summer unless it is absolutely necessary.. I had no trouble pulling it on the 8+ hour drive home..My truck felt better and got better gas mileage pulling my gooseneck, than it did pulling my nose-heavy Hart BP.
