air conditioners
Last activity 2012-08-05 10:39 PM
6 replies, 5015 views
toomanyponies
Reg. Aug 2012
Posted 2012-08-03 6:23 PM (#146046)
Subject: air conditioners
We are converting our gooseneck tack room into a sleeping/dressing area. How do we know how much our ceiling can hold in weight for an air conditioner? The smallest we have found is 92 lobs. Anything lighter out there?
sinful
Posted 2012-08-03 7:34 PM (#146047 - in reply to #146046)
Subject: RE: air conditioners
you have to get bracing in the roof before you try to put an A/C up there.  Mine weighs a 100#  Even if it only weighed 25#, the bouncing of the trailer would eventualy ripp the roof and you'll find your A/C on the floor and a big hole in the roof of your trailer.
toomanyponies
Reg. Aug 2012
Posted 2012-08-03 7:54 PM (#146048 - in reply to #146046)
That makes sense. Thank you.
Can anyone give me an idea of what kind of bracing to use, how to install...?
CTRider
Reg. Sep 2009
Posted 2012-08-04 8:41 PM (#146070 - in reply to #146046)
10010010025
What year, brand and model trailer do you have? Some are already braced to add an AC when they come from the factory. You might take the seriel number and call the factory and find out. If its a steel trailer a welder might brace it. If its aluminum I dont know. Maybe the factory can direct you.
Posted 2012-08-05 5:53 AM (#146074 - in reply to #146046)
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=17087
RidnClyde
Reg. Jun 2012
Posted 2012-08-05 9:14 PM (#146112 - in reply to #146046)
Speaking of installing AC units, anybody have recommendations on wire guage for a Dometic 13,500 BTU and fuse size?  Will 12-2 Romex work and a dedicated 30AMP in the panel?
Posted 2012-08-05 10:39 PM (#146114 - in reply to #146046)
12 awg wiring should be limited to a 20 amp circuit, which is enough for the 13,500 AC unit.
