Kiefer Built door repair?
Last activity 2013-10-04 10:45 PM
6 replies, 15115 views
muckmaster2010
Reg. Jul 2012
Posted 2012-07-27 2:33 PM (#145908)
Subject: Kiefer Built door repair?
I just recently purchased a 2001 Kiefer Built bp trailer and need to repair one of the rear doors. The door is kind of "floopy" and when I pull the trim back it looks like the inner wood core is rotted out. I know there was an issue in the past with Kiefer outsourcing doors but I think this is something different. I was wondering if I could simply take the door apart and replace the inner core with new wood? Has anyone tried this before? What kind of wood should I use/not use? Any other tips? Has anyone ever done this type of repair?Thanks
Traveler
Reg. Jul 2012
Posted 2012-07-28 10:42 AM (#145934 - in reply to #145908)
Subject: RE: Kiefer Built door repair?
Yes I have tried this better off getting the door totally rebuilt out of aluminum best buy you'll do
genebob
Reg. Nov 2007
Posted 2012-07-28 10:05 PM (#145938 - in reply to #145908)
That is in the year framework that Kiefer had problems with their doors. The inside of the door was built using treated wood that basically "ate" the aluminum. For a while Kiefer was replacing the doors, but that ran out long ago. Now Kiefer is owned by another company and getting a replacement door from them would almost be impossible. If you know a good fabricator that would be your best bet.
Posted 2012-07-28 11:45 PM (#145944 - in reply to #145908)
It can be rebuilt, but it is labour intensive whether by a fabricator or a DIY project. The most difficult issue is dismantling the door without damaging the inner and outer panels if they are still intact.
The original wood core has to be totally removed, the aluminum treated for corrosion and a new core installed. Do not use pressure treated plywood. It will ruin any aluminum against which it is placed. Baltic Birch plywood is among the most stable and strongest plywoods available. I have rebuilt ramps using this product with excellent long term results.
The wood can be epoxy bonded to the aluminum skins with marine epoxies such as System Three, WEST, MAAS etc. The epoxy will be thickened with various fillers to the consistancy of ketchup, and will bond the metal to the wood. It will also waterproof the new wood and eliminate any future rotting.
This door delamination issue has been previously discussed about the KB trailers. You might be able to google the older threads. If I'm not mistaken, after market doors are available, but at a substantial price. With some basic materials, aluminum sheet metal, plywood, epoxy and fasteners, rebuilding them could easily save  a great deal of money.
Posted 2012-07-29 12:19 AM (#145945 - in reply to #145908)
Here's an older inquirery that might offer some answers:
http://www.horsetrailers-online.com/forum/thread-view.asp?threadid=9838&posts=12
horsey1
Reg. Dec 2004
Posted 2013-10-02 8:47 AM (#155109 - in reply to #145908)
Originally written by jimmyjjohn on 2013-10-02 12:24 AM
Garage Door Repair Fontana is a famous overhauling company that undertakes renovation of garage doors in and around Fontana in San Bernardino County, California. We have created a niche for ourselves in the area of garage doors repair, leading our contemporaries with a beacon of light that overshadows them. We offer our dedicated services for anybody looking for economical, reliable and safe team of technicians honing great expertise.
Wow- I am honored to be in the presence of the Beacon of light! Even if it does overshadow everyone else..... Was that to be a complement to us?
Posted 2013-10-04 10:45 PM (#155169 - in reply to #155109)
Originally written by horsey1 on 2013-10-02 8:47 AM
No that was a SPAMBOT searching for door repair and then posting its spam...Never feed them, just click the report to moderator on this forum or if you encounter a SPAMBOT on another site, click on their notification method...
Edited by PaulChristenson 2013-10-04 10:47 PM
