Generator tips!
Last activity 2012-08-07 1:32 AM
11 replies, 8653 views
AZgrulla
Reg. Jan 2009
Posted 2012-07-26 9:43 PM (#145880)
Subject: Generator tips!
We are new to the LQ lifestyle and thus, camping with a generator. Out here in AZ, there is a lot of dust. When we bought the generator, Honda EU2000iA, we were advised to NOT place the unit on bare ground, rather, place it on top of a piece of plywood to prevent the dirt from being sucked up into the unit. The salesman said that this was the #1 reason generators come in for service.
Well, a few camping trips later, we noticed many with portable units do NOT place them on top of a board or some other object to prevent the dirt from getting up in the unit.
We have a handy spot in the back tack for out 2'x2' piece of plywood.
What are your tips/suggestions for maintaining your generator's health?
Posted 2012-07-26 10:26 PM (#145882 - in reply to #145880)
Subject: RE: Generator tips!
Dust will eventually kill any unprotected machinery. I would listen to the advice you have been given, and use the plywood. With the price you paid for the generator, it will be well worth your extra time, to take the best care of it you can.
It would be interesting to find out how long the other units last, whilst they are operated in the dirt. Instead of a decade of trouble free duty, they may only get a couple of years.
Regular maintenance consisting of routine oil changes, and air filters, will ensure a long, reliable life. Using synthetic lubricants will greatly decrease the wear the mechanicals normally would endure.
flyinghfarm
Posted 2012-07-27 11:20 AM (#145898 - in reply to #145880)
1000100100
using fuel treatments such as staybil, running it completely out of gas until it dies for storage for the winter, keeping oil level full, but not over filling, using non-ethynol gasoline I have heard, all are gonna help you in the long run.. all of what Gard said, too.
Edited by flyinghfarm 2012-07-27 11:21 AM
hornet
Posted 2012-07-27 11:32 AM (#145899 - in reply to #145898)
Good luck finding non-ethanol gasoline, that crap is in everything thanks to our government.
TSprint2
Reg. Dec 2004
Posted 2012-07-27 7:20 PM (#145914 - in reply to #145899)
I find that running ethanol free gas really does seem to make a difference with outboards, older and small engines. I use this URL to help locate stations that have non-ethanol gas:http://pure-gas.org/
flyinghfarm
Posted 2012-07-27 10:06 PM (#145919 - in reply to #145880)
1000100100
I live in a county that does not have one red light, but we have 3 gasoline stations here at the county seat, one of which does sell ethanol free fuel...  :-)
Posted 2012-07-27 10:22 PM (#145920 - in reply to #145880)
Most marinas and snow mobile dealers, sell ethanol free gas of 91 -93 octane. Gas stations nearby to these dealers, or where the equipment is mostly used, also usually has this gas available.
Posted 2012-07-27 10:55 PM (#145923 - in reply to #145880)
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=16953
steelsidedown
Posted 2012-07-28 2:41 AM (#145926 - in reply to #145880)
2nd marinas, also look for fuel at local air strips, the planes need ethanol free as well.
I drain the fuel after riding season is over in the fall, and start with fresh in the spring.
blackcows
Posted 2012-07-28 4:45 AM (#145929 - in reply to #145898)
100100100100252525
Originally written by flyinghfarm on 2012-07-27 11:20 AM
I use to do this with generators, mowers, weed trimmers, snow blowers, etc but I don't anymore.  I was told that it is better to add Stabil to some fuel and keep your engines full so that things stay lubricated and don't dry out.
Not sure if that is right or wrong but that is what I have been doing for a few years and haven't had any issues.
Posted 2012-07-28 7:38 AM (#145931 - in reply to #145880)
I got an old 2500 watt generator with a 5 horse L head Briggs... I run it once a year. Tank is full of fresh gas with a double shot of Stabil. You can pull the rope to roll the crank around to compression, pull the second time and it's running. I'll plug in a couple fans to add some load and let it run until it burns the tank clean. I'll refill with fresh gas, Stabil, and start it again, then shut it off until the next year... Been doing this since Hurricane Fran in 1996, hasn't failed to start yet.... Crankcase is filled with Mobil 1 10W30, same as in all of our other gasoline engines.
Posted 2012-08-07 1:32 AM (#146157 - in reply to #145880)
Start your generator at least once a month and let it run for a few minutes. If yours has a battery, trickle charge the battery from time to time to ensure it is ready to go.
