Small Living Quarters with slide
Last activity 2012-07-29 10:14 PM
14 replies, 9571 views
YODA
Reg. Sep 2009
Posted 2012-07-25 5:25 PM (#145832)
Subject: Small Living Quarters with slide
Does anyone make a 2 horse small living quarters with a slide. Trying to stay under 24 foot with a goose neck if possible. All I need is a bed. stove, and toilet/shower.
Kay
Posted 2012-07-25 6:08 PM (#145834 - in reply to #145832)
Subject: RE: Small Living Quarters with slide
50025
Almost any manufacturer will build one, but it is highly unlikely that you will find a used unit.  A two horse with a 10' short wall would have less than a 24' long floor length.
YODA
Reg. Sep 2009
Posted 2012-07-25 8:54 PM (#145841 - in reply to #145832)
Thanks - Can you recommend any manufacturers to start with. In doing a quick search Logan appears to have what you mention, but Heart shows nothing. Any help would be appreciated.
If I understand correctly, with a 24 foot floor and the standard goosneck overhang I am looking at a roughly 28 foot overall length. - Correct?
jackbrat
Posted 2012-07-25 9:24 PM (#145842 - in reply to #145832)
500100
Trails West and Exiss, Featherlite
horsey1
Reg. Dec 2004
Posted 2012-07-25 9:32 PM (#145843 - in reply to #145832)
A gooseneck will be 8'.
rose
Posted 2012-07-25 9:59 PM (#145844 - in reply to #145832)
10005001002525
Not positive, but think you will have to go to an 8' shortwall in order to get a slide out.
RidnClyde
Reg. Jun 2012
Posted 2012-07-26 8:01 AM (#145854 - in reply to #145832)
Just curious, if all you need is a bed, stove and toilet/shower why do you need a slide out?
A counter area for a stove, toilet and shower can all fit along a decent size long wall (see forum layouts/renovation ideas or JB conversions).
Posted 2012-07-26 8:25 AM (#145856 - in reply to #145832)
Try contacting Blue Ribbon in Youngstown OH. They can and do, custom build almost anything.
Spin Doctor
Reg. Nov 2008
Posted 2012-07-26 8:37 AM (#145857 - in reply to #145832)
Good friends run a conversion company and they recommend nothing less than a 6' slide, ideally an 8' to allow room for couch or dining area. They did a 6' slide last spring and I personally thought it was a waste as just had basically a large chair in it.
So to get a 8' slide, you will need at least an 10' short wall to make the trailer frame work correct IMO. But you will lose a lot of counter wall space with a slide.
They have done almost every trailer and slides are not created equally. Some better, some not so good. They recommend a hydraulic system for the slide. Electric just doesn't hold up in their opinion.
Kay
Posted 2012-07-26 9:03 AM (#145859 - in reply to #145832)
50025
A two horse with a 10' short wall would be 21' on the floor, plus 7'6" or 8' for the gooseneck.  You will need at least this much length for a slide out.  Hart, Cimarron, and most manufacturers will build this.  Do not assume that a model is not available just because you don't see it in a brochure or ad.  Advertising is going to display common models and sizes or somethng spectacular.  One thing to think about is that a slide out (you definately want hydraulic, by the way) does not enable more "stuff" in a living area, it just gives you more floor space.  As a matter of fact, the frame and mechanism of a slide out consumes wall space that could accommodate more cabinets, a larger refrigerator, etc.
RAF
Reg. Jan 2009
Posted 2012-07-26 9:10 AM (#145860 - in reply to #145832)
you can get a 8.5 LQ 2 horse with a 6 ft. slide out total length 24'6" Trail Rider Horse Trailers
RAF
Reg. Jan 2009
Posted 2012-07-26 9:13 AM (#145861 - in reply to #145832)
you can get a 8.5 LQ 2 horse with a 6 ft. slide out total length 24'6" Trail Rider Horse Trailers sorry that is a bumper pull the goose neck would be 27 ft. 9 in. with a 5 ft. slide
YODA
Reg. Sep 2009
Posted 2012-07-26 11:13 AM (#145867 - in reply to #145832)
Thanks much folks for the information here and in the private messages I received. Looks like I have a lot of homework to do and a few calls to make. Great information - Thanks again.It appears I can stay in the overall 26 - 29 foot goose neck length - equivalent to a 24 foot bumper pull overall length with all of the fittings we would be looking for. To answer the question about the slide you might say I am dimensionally challenged :-) I have a short one on my current 5th wheel where the sofa moves back to give extra floor room by the dinning table. It is a hand pull out (no electric or hydraulic stuff to worry about) And is held in place by a couple of jack poles - works well.Ill also consider the 3 horse model as the 3rd bay can hold extra horse or camping stuff too.
CoughlinShadow
Reg. Dec 2011
Posted 2012-07-26 1:32 PM (#145871 - in reply to #145867)
This SHADOW model has lots of room, but can also be built wtih a slide out and several other options as well.. take a peek here on Horse Trailer World
http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=392169
OGM
Reg. Jun 2012
Posted 2012-07-29 10:14 PM (#145955 - in reply to #145832)
Shadow makes a nice small LQ with Slide out. Saw at QH Congress. I think it was a 8.5' sw
