how to tell if trailer has steel frame or aluminum?
Last activity 2012-07-21 3:28 PM
11 replies, 10731 views
balakai
Reg. Feb 2012
Posted 2012-07-19 12:52 PM (#145694)
Subject: how to tell if trailer has steel frame or aluminum?
2001 Gore bumper pull, seller thinks it's all aluminum but isn't sure. It has an aluminum floor, sides look like alumimum on the bottom half, painted aluminum on the top half.
Posted 2012-07-19 1:04 PM (#145696 - in reply to #145694)
Subject: RE: how to tell if trailer has steel frame or aluminum?
They are advertised as having a steel chassis for "additional strength"
The easiest way to find steel is to check with a magnet and look for rust
balakai
Reg. Feb 2012
Posted 2012-07-19 1:18 PM (#145697 - in reply to #145694)
So the steel is in the "base", the floor framing?  How much lighter would an all aluminum chassis be for a 3 horse BP?  Is it a massive weight difference?
If not, is the main issue of aluminum vs. steel just durability of the chassis?
AZgrulla
Reg. Jan 2009
Posted 2012-07-19 1:38 PM (#145698 - in reply to #145694)
I have a steel frame, aluminum body GN3h...weighs 5450#, my steel 28' LQ weighs 9700#, so an all aluminum would be in the 3k range.
durability is the biggest issue between steel/aluminum frames. We go over a lot of bumpy roads when we camp/travel so the steel frame is ideal for this. If you are just going to drive on paved roads, aluminum is fine. I have a friend with an ALL aluminum LQ and her frame is starting to bend/twist...doors are not sitting straight even though the hinges/pins are fine. She has never had an accident.
A steel frame on the type of trailer you are wanting will not add a lot of weight as long as it is an aluminum skin. Also, look at the roof...ours is aluminum and many use fiberglass up there which is a lot cooler.
Good luck.
balakai
Reg. Feb 2012
Posted 2012-07-19 2:18 PM (#145700 - in reply to #145694)
Thanks. I think the roof is fiberglass but not positive. Might go take a look this weekend.
Posted 2012-07-19 2:40 PM (#145701 - in reply to #145694)
There is not a Huge difference is weight between a steel vs an aluminum trailer. They use a heavier grade of aluminum in order to the same strength as steel.  In general I've heard numbers of 600-800lbs difference between the two types of trailers. So yes the aluminum is lighter, But most trucks don't notice that kind of difference in weight.
For example I pulled a Logan 4h LQ loaded with horses from SLC to Yellowstone Park. Trailer weighed in at 16,000lbs. My truck got 12 mpg.  Two weeks later I picked up an empty Logan 4H non-LQ trailer.  Empty weight was 6,000lbs and towed it from Boise Id to SLC. I got 12.5 mpg. 10,000lbs lighter in weight but pretty much the same frontal area and wind resistance. The differnce to my Ford F350 was .5 mpg in better fuel mileage. And some of that difference has to be credited to the drive to Yellowstone climbing over several mountain passes vs the drive from Boise being pretty flat freeway cruising.
If you are in an underpowered truck, Then 800 lbs is a big deal. But most current tow trucks with diesel engines, the weight is just one small factor, and the difference between Aluminum and Steel is not a decision maker for fuel mileage.
whitewood
Reg. Jun 2009
Posted 2012-07-20 9:11 AM (#145713 - in reply to #145694)
alminum is hands down tougher. There is a lot of ranchers in this area that have 10 to 30 miles of rock road going into their places. Granted it is tough on everything, but the aluminums that are well built, take it much better than any steel.
balakai
Reg. Feb 2012
Posted 2012-07-20 5:13 PM (#145723 - in reply to #145694)
Went to look at the trailer. It's in rougher shape than what shown in the pics on craigslist. LOTS of rust on the steel frame, including some of the welds. No way it's worth 8,000, in my opinion.Thanks for the info. We've been looking for about 6 months and I'm starting to get a little frustrated.
Posted 2012-07-21 8:57 AM (#145732 - in reply to #145694)
Now you know how to tell the difference between a steel and aluminum frame.
balakai
Reg. Feb 2012
Posted 2012-07-21 9:16 AM (#145733 - in reply to #145694)
Yeah, true, but that was the least of my worries once I got there and actually saw the trailer.  Steel vs. aluminum was the last thing I was concerned about once I saw the condition of the trailer!
Now we're back to thinking we should just bite the bullet and finance a new trailer.
AZgrulla
Reg. Jan 2009
Posted 2012-07-21 3:06 PM (#145737 - in reply to #145694)
For 8k, you can get a nice aluminum 2 horse or a nice down payment on a bigger trailer.
steelsidedown
Posted 2012-07-21 3:28 PM (#145738 - in reply to #145694)
magnet! :-)
