Acceptable Voltage Range For AC?
Last activity 2012-07-08 1:13 PM
4 replies, 5077 views
walkin
Posted 2012-07-03 3:19 PM (#145334)
Subject: Acceptable Voltage Range For AC?
500100
I seem to always get a spot with low voltage. What are the acceptable parameters that you should have to properly run the LQ?Thanks!
Posted 2012-07-03 3:36 PM (#145335 - in reply to #145334)
Subject: RE: Acceptable Voltage Range For AC?
The standard for house hold circuits is 117 V AC. A shore cord is often in the 110 V -120 V range depending upon many variables. Many converters used in LQs, are made to run on voltages varying from 105 V- 130 V AC.
smoothride
Reg. Mar 2005
Posted 2012-07-04 6:37 AM (#145344 - in reply to #145334)
The surge protector/power conditioner in the audio rack shuts down our power when it reaches 111 volts AC. I have never seen it above 123 volts
jakefreese
Reg. Nov 2009
Posted 2012-07-08 12:40 PM (#145436 - in reply to #145334)
It should be 112-128vac
cajunmuleman
Reg. Oct 2011
Posted 2012-07-08 1:13 PM (#145437 - in reply to #145334)
They are rated at 115V plus or minus 10 percent
