coating on horse trailer floor.
Last activity 2012-06-14 6:15 AM
7 replies, 5934 views
Horsemen
Reg. Oct 2008
Posted 2012-06-13 6:34 AM (#144774)
Subject: coating on horse trailer floor.
I want to coat the floor of an 1998 Sundowner trailer horse area, want to know what you recomend as far as a good floor coating, and what preperation do I need to do before coating.  I was thinking about Rino bed linner any suggestions.
Horsemen
Reg. Oct 2008
Posted 2012-06-13 3:41 PM (#144787 - in reply to #144774)
Subject: RE: coating on horse trailer floor.
well I scrubbed it with soap and water and now I am going to scotch pad it with some acetone to prep the floor before I apply the bed liner coating, should I zinc chromate the aluminum before the coating Thanks
barrelrunner66
Reg. Oct 2010
Posted 2012-06-13 7:14 PM (#144796 - in reply to #144774)
I was hoping Gard would answer you. He did a GREAT set of posts on how to do what you are talking about. Sometimes you have to Google the question because if it's older than a year the forum search won't find it but google will and lead you to his posts.<\p>
We actually did this in our past trailer following Gard's instructions. Seems like we used Muratic Acid to clean and etch out any corrosion. BE CAREFUL and use a mask!! Once this was done, any pits showed that indicated a problem. We were lucky and didn't have any. We used the brand bedliner that Autozone carries. laid down two coats. AWESOME! Hope this helps...at least some. <\p>
Posted 2012-06-13 10:28 PM (#144804 - in reply to #144774)
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=12471&posts=85
Horsemen
Reg. Oct 2008
Posted 2012-06-14 12:51 AM (#144806 - in reply to #144796)
thanks, I did do a search on here before I posted and it did not come up, so I googled it like you said and found it, it is very helpful, I was a fraid to use muratic acid because of the fumes being in a some what close area, the fumes will harm other medals, but if you all are doing it must not be bad, Gard know his stuff when it come to this, in the marine trade we used a acid wash that was a milder acid to clean the alum. but it is pretty costly to do a floor like in a trailer
Thanks again
Horsemen
Reg. Oct 2008
Posted 2012-06-14 12:56 AM (#144807 - in reply to #144804)
Thanks Gard,  what you wrote up is going to be very helpful, the floor is in great shap for being thirteen years old and the people that had this trailer before me took very good care of it and I am only the second owner
Horsemen
Reg. Oct 2008
Posted 2012-06-14 5:59 AM (#144809 - in reply to #144774)
there is very little corrosion on the floor and that is not bad, they did or the factory put drain holes in the floor and for fourteen years old I think that it is not that bad, I said it was thirteen years old but meet fourteen
Horsemen
Reg. Oct 2008
Posted 2012-06-14 6:15 AM (#144810 - in reply to #144774)
Plus I was afraid of taking all the anodizing off the good areas and most of it still has the anodizing on it which the acid will, but you all are getting good life out of your floors thats good enough for me
