another wiring question
Last activity 2012-06-02 4:38 PM
5 replies, 4246 views
kentuckyrain
Reg. Apr 2008
Posted 2012-06-02 1:19 PM (#144437)
Subject: another wiring question
The tail lights, brake lights and turn signals all work with the truck's headlights in the off or auto position but when the head lights come on or are manually turned on I lose tail lights, brake lights and turn signals, although all the clearance lights do come on. The truck is a 2002 F250 SD the trailer is a 2000 Legend and I do use an adapter. Any ideas? Thanks,  Donna
Posted 2012-06-02 1:38 PM (#144438 - in reply to #144437)
Subject: RE: another wiring question
It sounds as if there might be an open grounding problem between the truck and trailer. I would also recommend that the adapter be replaced with a dedicated plug.
kentuckyrain
Reg. Apr 2008
Posted 2012-06-02 2:55 PM (#144441 - in reply to #144438)
  Well, that sounds great Gard! Wish I knew what you meant or what to do about it!
BigT
Posted 2012-06-02 3:20 PM (#144442 - in reply to #144437)
I believe what gard is saying is to get rid of the adapter and install the plug on the trailer to match the truck.
kentuckyrain
Reg. Apr 2008
Posted 2012-06-02 4:11 PM (#144443 - in reply to #144442)
Well that part I did understand!
kentuckyrain
Reg. Apr 2008
Posted 2012-06-02 4:38 PM (#144444 - in reply to #144443)
Thanks, all! My brilliant husband found the short and all is working now...
