best way to insulate fiberglass roof?
Last activity 2012-05-28 10:33 PM
4 replies, 8302 views
acy
Reg. Oct 2006
Posted 2012-05-28 6:58 AM (#144250)
Subject: best way to insulate fiberglass roof?
A friend has a Gore trailer, and plans to fix up the DR area.  What is the best insulation (and way to install it)  to use underneath the  fiberglass roof?    thanks!
ellisor
Reg. Oct 2010
Posted 2012-05-28 10:24 AM (#144254 - in reply to #144250)
Subject: RE: best way to insulate fiberglass roof?
I used Styrofoam sheets. Available at building supply companys in different R values and and thickness. Cut to exact fit between frame\joists glue to roof or allow finish ceiling to support panel. Tape joints with foil\aluminum backed tape.
Posted 2012-05-28 1:19 PM (#144255 - in reply to #144250)
Contact, Jackson Gore.... He built it, he'll tell you the best way to insulate it.
1-800-334-3488
Voice: (910) 642-4298
FAX: (910) 640-1133
Marla
Reg. Mar 2008
Posted 2012-05-28 8:32 PM (#144263 - in reply to #144254)
500
If you use the styrofoam sheets be sure to use the closed cell type and put a layer of foil backed bubble wrap between the roof and the styrofoam. Marla
Posted 2012-05-28 10:33 PM (#144268 - in reply to #144250)
The best results I've had, is by installing the double foil faced rigid insulation, secured in place with polyurethane construction adhesive. If the area is curved, scarf cuts can be made into one side of the surface, allowing the foam board to be profiled to meet the curvature of the roof.
Any gaps on the edges can be filled with foam insulation, and then covered with the metalic tapes.
