Stranded friend- I need trouble shoot electric jack
Last activity 2012-05-03 5:00 PM
10 replies, 7259 views
walkin
Posted 2012-05-02 9:44 AM (#143603)
Subject: Stranded friend- I need trouble shoot electric jack
500100
Batteries charged, plugged into shore power, nothing, no motor sound. Then plugged into truck as well, nothing. She has to leave today.Thanks for any help!
BigT
Posted 2012-05-02 9:49 AM (#143604 - in reply to #143603)
Subject: RE: Stranded friend- I need trouble shoot electric jack
I would first check if there is a dedicated fuse for the jack, and see if it is not blown.
Sheryl
Posted 2012-05-02 11:05 AM (#143606 - in reply to #143603)
She should be able to crank it manually.  I had to do this one time when my batteries were bad.  It did help to hold the electric switch on while I was cranking.
Posted 2012-05-02 2:00 PM (#143608 - in reply to #143603)
If the jack has easily accessable, external electrical terminals, you might try to use an automotive jumper cable from the LQs B+ battery terminal to the jack's B+ terminal. If it runs, you can conclude that inline fuses or relays as being the source problems.
Most electrical jack problems are caused by dirty terminals or low battery voltage. Cleaning the connections, and adding dielectric grease before they are reassembled, can eliminate many issues.
walkin
Posted 2012-05-02 3:59 PM (#143612 - in reply to #143603)
500100
She says that when the electric jack, equalizer systems, was installed, after market, that she did not get the crank back?I was able to put a charger on batteries to get it to lift up. Alas, she cannot leave til tomorrow! I guess the batteries were completely dead.Thanks !!
headhunter
Reg. Oct 2004
Posted 2012-05-02 7:38 PM (#143617 - in reply to #143603)
50010010025
I'd be really curious to find out why her batteries weren't being charged while she was plugged into shore power.
walkin
Posted 2012-05-03 10:07 AM (#143649 - in reply to #143603)
500100
I wonder the same thing. and they do not charge when plugged into the truck either?
Anyway, she is on the road, and will take the trailer in as soon as she gets home.
Posted 2012-05-03 11:51 AM (#143656 - in reply to #143603)
1000500100100100252525
I would get a crank just in case the trailer is on the truck
lesliemal
Reg. Sep 2007
Posted 2012-05-03 12:34 PM (#143657 - in reply to #143603)
Most LQs have a "battery" switch .Mine is located at the battery box. I had one before that was up near the bed in the LQ on an interior wall. Is it possible that the switch was turned off? Just something to check.
blackcows
Posted 2012-05-03 3:47 PM (#143665 - in reply to #143603)
100100100100252525
What brand of jack?  Might have a manual override.
genebob
Reg. Nov 2007
Posted 2012-05-03 5:00 PM (#143667 - in reply to #143603)
Is it a bad ground?
