Bearings
Last activity 2012-04-22 1:22 AM
5 replies, 4858 views
Stevevaus
Reg. Mar 2012
Posted 2012-04-21 9:10 AM (#143259)
Subject: Bearings
I'm new to horse trailers - fixing one up for my wife's birthday.
I called local trailer joint to ask about having them check bearings, brakes, etc. They say the only way to check the bearings is to take them apart and once they take them apart they have to repack replace etc. anyway . . . huh?? That seems bogus to me.
Isn't there a way to check the bearings without dismantling them?
Posted 2012-04-21 9:43 AM (#143260 - in reply to #143259)
Subject: RE: Bearings
Nope.... You can jack up the trailer and shake the wheel, but that just lets you know you got one loose that probably need replacing anyway. Be sure to replace the grease seals while it's apart.
Posted 2012-04-21 7:58 PM (#143268 - in reply to #143259)
Originally written by Stevevaus on 2012-04-21 9:10 AM
It's No Big Deal...you should repack your trailer bearings once a year.
wyndancer
Reg. Apr 2007
Posted 2012-04-21 8:16 PM (#143271 - in reply to #143259)
At the end of the day....they're correct.
You need to repack the bearings? Yes, you'll need a new grease seal. And once they have things "a part" they'll be able to see any unusual wear on the "timken" bearing and/or their respective races..
So yeah...to do the job "right" they need to pull it all apart.
Posted 2012-04-22 12:53 AM (#143281 - in reply to #143259)
Originally written by Stevevaus on 2012-04-21 6:10 AM
I'm new to horse trailers - fixing one up for my wife's birthday. I called local trailer joint to ask about having them check bearings, brakes, etc. They say the only way to check the bearings is to take them apart and once they take them apart they have to repack replace etc. anyway . . . huh?? That seems bogus to me. Isn't there a way to check the bearings without dismantling them?
Yes ... there is a way to check bearings.  Use an ultrasonic probe.  Industry uses the technique on critical equipment.  One will be able to detect a bearing on the way to failure.  Most people just take the wheel apart and inspect, repack and replace the seal.  ... Sure and cheap prevention.
Posted 2012-04-22 1:22 AM (#143282 - in reply to #143259)
Here's a write up on repacking the wheel bearings. from Mr truck's site..
http://www.mrtrailer.com/hosspullerbrakes.pdf
Anybody that can follow directions can do it...  Just takes time and a few parts.
You can see why seals and repacking are done at an inspection.
