Sway bars
Last activity 2012-04-17 8:39 PM
7 replies, 9822 views
jenn689
Reg. Apr 2012
Posted 2012-04-15 7:23 PM (#143132)
Subject: Sway bars
Forgot to add this to my previous post about the living quarters lights-----this trailer has the apparatus on the hitch for sway bars,, but the previous owner couldn't find them.  Can you buy just the bars?  Or would it be better to just get the whole thing.   Do I even need sway bars on a 2000 3 horse bumper pull Sooner trailer??
Posted 2012-04-15 7:47 PM (#143134 - in reply to #143132)
Subject: RE: Sway bars
The best way to know, is to try the trailer without the bars. Try it first, pulling empty. If things work well, try a load. Where the horses are placed within a 3H BP, will directly result in how well the trailer pulls and how stable it will be.
Many trailers need no sway aids. The only way you will know for sure, is to actually try pulling the trailer without any installed. Your trials should include braking, corners and variable speeds, and especially, braking while turning.
Edited by gard 2012-04-15 7:49 PM
Posted 2012-04-16 11:12 AM (#143146 - in reply to #143132)
Posted 2012-04-16 11:18 AM (#143147 - in reply to #143132)
That's what happens when I try to post from somebody else's computerThe vehicle you tow with will also have some effect on your need for weight distributing hitch.If you are towing your bumper pull horse trailer with a lighter vehicle, the need will become more apparent than if you are towing with a dually pick up. I pull several trailers for constructions,, Dump trailers, equipment trailers that all weigh up to 14,000lbs and have never felt the need for weight distribution on my 1 ton Ford pickup.As Gard suggest. Give it a try, if you sense an unstable load, then you can add the appropriate hitch
Yvette
Reg. Jul 2006
Posted 2012-04-16 1:25 PM (#143151 - in reply to #143132)
100100100
Depends not only on your tow vehicle, but the hitch attached to it. From your description of the trailer unless you have a class IV, that is class four, hitch on your vehicle, chances are you will be overloading your hitch, assuming it's a class III (three) without the weight distributing attachment. Can you and have people gotten away with it. Most likely, but it's up to you how safely you want to tow.
Yvette
Reg. Jul 2006
Posted 2012-04-16 1:28 PM (#143152 - in reply to #143132)
100100100
It never ceases to amaze me what a simple search can bring up. <9>
http://www.hitchanything.com/Weight-Distribution-Hitch/
jenn689
Reg. Apr 2012
Posted 2012-04-17 8:29 PM (#143180 - in reply to #143132)
jenn689
Reg. Apr 2012
Posted 2012-04-17 8:39 PM (#143181 - in reply to #143132)
Thanks everyone for the input,,, It is a very helpful thing that you do,, giving advice to us newbies,,, sometimes, as "obvious" as the answer seems to those experianced,, it isn't the case for  us who are new to this.   I certainly appreciate the knowledge that I have gained from many discussions here!! A great website!!
