GMC 2500 Duramax/Allison - Dealer says needs x,y,z....
Last activity 2012-04-06 9:37 PM
2 replies, 4231 views
ncsuacd
Reg. Sep 2007
Posted 2012-04-06 9:20 AM (#142851)
Subject: GMC 2500 Duramax/Allison - Dealer says needs x,y,z....
Went to dealership for oil change.
Now they are saying I need:
Battery cleaning ($12, Labor $75 ???)
Transmission filter change (along with fluid) ($lots).
I seem to recall that the transmission filter wasnt supposed to be changed for like a LOT more miles than 50k....
Truck right at 50k miles... 2008 GMC Sierra 2500 Duramax/Allison...
Posted 2012-04-06 10:14 AM (#142852 - in reply to #142851)
Subject: RE: GMC 2500 Duramax/Allison - Dealer says needs x,y,z....
You can clean the battery yourself with water and baking soda... So far as the transmission, I change my spin on filter every 15000 miles, also pull the trans drain plug and about 7 quarts of fluid will drain. Refill with fluid and replace spin on filter. Spin on filter is $28.00 at GM dealership, about $11.00 online. Filter screen in the pan is replaced when the transmission is rebuilt. GM does NOT recommend flushing the trans, just replace what you drain from the pan when replacing the spin on filter. My truck is a 2001 3500 with 110000 miles with probably 100000 of that towing better than 10,000#.
This is what Allison says do!!
http://www.allisontransmission.com/servlet/DownloadFile?Dir=publications/pubs&FileToGet=SA5429EN.pdf
Source for spin on Allison 1000 series trans filters... They are about the same price at an Allison dealer/repair shop. This is the Fleetguard number, they will run about $15.00... Fleetguard HF35296
http://madjacksynthetics.com/Allison-1000-Transmission/Parts-Pans-Etc/Allison-Spin-On-Oil-Filters-29539579/prod_13.html
Posted 2012-04-06 9:37 PM (#142863 - in reply to #142851)
Originally written by ncsuacd on 2012-04-06 9:20 AM
Went to dealership for oil change.Now they are saying I need:Battery cleaning ($12, Labor $75 ???)Transmission filter change (along with fluid) ($lots).I seem to recall that the transmission filter wasnt supposed to be changed for like a LOT more miles than 50k....Truck right at 50k miles... 2008 GMC Sierra 2500 Duramax/Allison...
Every 30,000 miles unless you are involved in HEAVY towing...here the complete service schedule for your Duramaax/Allison equiped truck... http://www.dieselplace.com/forum/showthread.php?t=33348
