110 interior lights
Last activity 2012-03-25 8:52 AM
3 replies, 5211 views
reiner11
Reg. Sep 2011
Posted 2012-03-24 6:00 PM (#142450)
Subject: 110 interior lights
Does anyone know of a 110v flush mount ceiling light that is designed like the 12 volt to mount without having to try and fit a gang box in the ceiling or some kind of light that all you do is feed the wire through the ceiling. My trailer is a 110 only and am having a time finding 110v stuff to fit in the limited space between the walls and what will be the finished panel. Thank you
Posted 2012-03-24 9:29 PM (#142457 - in reply to #142450)
Subject: RE: 110 interior lights
Other than a surface mount fluorescent fixture, I can't think of any. Heat is an issue with the larger voltages.
They do make gang boxes that are half as deep as standard boxes, that can be used for LQ interiors. They are commonly available at hardware and big box stores.
http://www.homedepot.com/buy/electrical-electrical-boxes-conduit-fittings-boxes-brackets/carlon-1-gang-17-cu-in-shallow-old-work-box-184225.html
Here's one that's only an inch deep:
http://www.goodmart.com/products/raco-404-1-in-deep-shallow-switch-box.htm
reiner11
Reg. Sep 2011
Posted 2012-03-25 7:11 AM (#142463 - in reply to #142450)
Thank you Gard. Your help is much appreciated.
ellisor
Reg. Oct 2010
Posted 2012-03-25 8:52 AM (#142464 - in reply to #142450)
Take a look at the Led "puck" and "strip" lights. Some are made to recess, some are only an inch or so thick. Good light source also.
I used a three Led strip over the sink and have two sets of three light pucks in the neck.
