Is my hotwater heater gas and electric?
Last activity 2012-03-12 1:08 PM
9 replies, 5609 views
blackcows
Posted 2012-03-11 5:58 PM (#141938)
Subject: Is my hotwater heater gas and electric?
100100100100252525
I have the standard Suburban 6 gallon water heater on my trailer, never used it becuase we have never camped.  I have run it on propane to see that it works and now I am wondering if it is gas and electric?  How would I know and if it is both does it turn on each time I am connected to my generator?
Posted 2012-03-12 12:06 AM (#141964 - in reply to #141938)
Subject: RE: Is my hotwater heater gas and electric?
You need battery voltage to light it, gas or electric to run it. Any time your converter and battery swith is on, you should have B+ available to the igniter for starting the heater.
blackcows
Posted 2012-03-12 6:03 AM (#141969 - in reply to #141938)
100100100100252525
Thanks Gard...I am still a bit confused.  Will I always need gas to make hot water?
Posted 2012-03-12 8:16 AM (#141977 - in reply to #141938)
When you select your heater to on, and don't select a gas option, the heater if equipped, will use AC electric for its power source. This is one way you can trouble shoot the heater if it doesn't light off on gas.
Go on line and research your specific heater model for an opperator's manual. The model # can be found on a data plate, attached to the heater and is accessable through the service panel from the outside of the trailer.
blackcows
Posted 2012-03-12 10:06 AM (#141981 - in reply to #141938)
100100100100252525
I figured it out.  I have an SW6 D which means propane only.  Any guess on how long it takes to heat 6 gallons of water?
crowleysridgegirl
Reg. Apr 2005
Posted 2012-03-12 11:16 AM (#141983 - in reply to #141981)
2000500100
I don't know which water heater we have,but,I can tell you from experience that it doesn't take very long.
blackcows
Posted 2012-03-12 11:19 AM (#141984 - in reply to #141983)
100100100100252525
Originally written by crowleysridgegirl on 2012-03-12 11:16 AM
Thanks....so you turn it on in the am for an am shower?  No need to run overnight?
crowleysridgegirl
Reg. Apr 2005
Posted 2012-03-12 11:43 AM (#141987 - in reply to #141984)
2000500100
no,not unless you are in a big hurry to get out the door,you can turn it on and drink some coffee or whatever,in a pretty short while,it's ready.Saves on propane,and,I don't really like having it on all PM anyway if there's no need.
Posted 2012-03-12 11:45 AM (#141988 - in reply to #141938)
Less than half an hour, max.
griffsmom
Reg. Oct 2009
Posted 2012-03-12 1:08 PM (#141994 - in reply to #141938)
I have that same model and I would say from the time you light it, walk back in the trailer and turn the water on, in about 2 minutes you will have hot water starting to make it to the faucet. Very quick.
