New Cord or Extension?
Last activity 2012-03-12 10:19 PM
10 replies, 6533 views
blackcows
Posted 2012-03-11 5:54 PM (#141937)
Subject: New Cord or Extension?
100100100100252525
I have drivers side entry LQ, never camped but will probably stay at a local event center a few times this year. After reading a thread here and looking at the spaces at the campground I now understand my trailer is setup a bit backwards for the spaces.  While I could back in the family that we travel with has a trailer set up the other way so it will be nice to share a common area.  I would guess that currently I have a 10 to 15 foot cord wired into my converter.  Would it be possible (and safe) to just buy an extention?  I think another 10 foot would be good.  Or will I need to change my cord?  Anybody have an easy way to get the cord under the trailer other than having my daughter climb underneath?  I was thinking that I could throw a cheap fish tape on the trailer.
Mike
Posted 2012-03-12 12:36 AM (#141966 - in reply to #141937)
Subject: RE: New Cord or Extension?
WalMart sells a 10AWG 20' extension cord for about ~$40. It's easy to just throw one end under the trailer to the other side. You will need an adapter for a 15/20 Amp service
cajunmuleman
Reg. Oct 2011
Posted 2012-03-12 7:53 AM (#141972 - in reply to #141937)
I have the door on the drivers side along with my electricity, water and sewer. I have stayed at a few stites that use a common electric pole and water to serve two sites so I have had to cross my water hose and power cord over to the passenger side, simply pull cord out and walk under the neck before putting the trailer legs down.
blackcows
Posted 2012-03-12 7:58 AM (#141973 - in reply to #141972)
100100100100252525
Originally written by cajunmuleman on 2012-03-12 7:53 AM
Well of course I could do it that way but it would be much to simple....I was looking for a more complicated solution that would require me to buy something ;)
blackcows
Posted 2012-03-12 7:59 AM (#141974 - in reply to #141966)
100100100100252525
Originally written by gard on 2012-03-12 12:36 AM
Would this be a heavy enough cord to run AC?
cajunmuleman
Reg. Oct 2011
Posted 2012-03-12 8:03 AM (#141975 - in reply to #141937)
Yes it would. Make sure it has a 30 amp RV plug not a 15 amp ( regular ) plug
Posted 2012-03-12 8:07 AM (#141976 - in reply to #141937)
We have one in each of our trailers, and with a 30 amp capacity, have had no problem running any of the electrical accessories. It comes with the same 30 amp plug as the factory shore cord, the reason you need an adapter for the smaller services.
bjhouten
Posted 2012-03-12 11:24 AM (#141985 - in reply to #141937)
5002525
Walmart sells a 30amp RV extension cord. I have a 50' one that has come in pretty handy a couple of times.
flyinghfarm
Posted 2012-03-12 2:19 PM (#141997 - in reply to #141937)
1000100100
We also carry a schedule 40 piece of sewer pvc pipe on the side of our hayrack, it has come in handy on the times we have had to pull the cord straight behind the trailer to hookup.  That way in saddling at the rear tack etc, there was not an issue with our stock or anyone elses tromping the power cord or water hose as the case may be.
cajunmuleman
Reg. Oct 2011
Posted 2012-03-12 3:14 PM (#142000 - in reply to #141937)
That sounds like a good idea
Posted 2012-03-12 10:19 PM (#142019 - in reply to #141937)
Originally written by blackcows on 2012-03-11 5:54 PM
Mike
http://www.gorhamschaffler.com/wire_size_calculator.html
