Repair roof seam on trailer
Last activity 2012-03-12 12:41 AM
13 replies, 23695 views
smoothhorse
Reg. Feb 2012
Posted 2012-02-26 1:36 PM (#141456)
Subject: Repair roof seam on trailer
I have an 2005 Kieffer trailer/3h/full lq. Need to repair the "caulk" on top seam and not sure what to use and the best way to approach it.Trust members of this site to give me a lot of good information!
jackbrat
Posted 2012-02-26 5:07 PM (#141465 - in reply to #141456)
Subject: RE: Repair roof seam on trailer
500100
Gard suggested the Marine grade poyurethane product called Sikaflex. It comes in clear, black or white. I am going to purchase the clear though. I also suggest (if you have never caulked before) to watch some youtube videos on good caulking ideas. I myself have never done it and found the youtube videos helpful.
smoothhorse
Reg. Feb 2012
Posted 2012-02-26 5:26 PM (#141466 - in reply to #141465)
The service men at Camping World told me about Nucote and the web had articles about A-seal for aluminum or Eternabond over existing. I have gotten very confused and frutstrated. Really would like something to go over existing as a precaution but don't want to strip it. If I have to I will. Nothing's ever easy. Appreciate advise to minimize my mistakes.
Posted 2012-02-26 7:05 PM (#141473 - in reply to #141456)
Welcome to the forum
I stripped the old caulk from my trailer. Used a wire brush in a power tool. Having a clean metal surface lets the new caulk stick and seal well. Putting new caulk on top of old caulk is just a waste of time and material. The old caulk leaked, so you expect the new caulk to stick to the old caulk and dirty metal ? And seal well ?? Makes for a messy and unsightly job too... since you have to cover the old caulk seam completely.
I would use a colored caulk to help resist the sun's UV rays. Clear gets cloudy after sun exposure.
gabz
Posted 2012-02-26 7:55 PM (#141476 - in reply to #141473)
1000100100100252525
I'm with hosspuller on this one.  Take a very sharp linoleum / utility knife to start with and remove ALL the old caulk. I've never had to use any power tools, but I bet a Dremel with a sanding disk would work good in that kind of area.
There are several de-gunking products that are safe to use on powder-coat or painted surfaces... check with your trailer dealer, RV place, or car/truck automotive dealerships. Use this to remove any little bits of caulk.
Wash the area thoroughly with soap and water and rinse well (vinegar in the rinse water won't hurt.
Once it's really clean, apply caulk of choice. I always use white, as that's what color my trailer is. :
Posted 2012-02-27 8:49 AM (#141489 - in reply to #141456)
This may work on a steel trailer, but don't use any sharp tools on an aluminum roof or aluminum product. If the metal is scored by a blade, it will set up a positive area for localised corrosion. Very quickly you will have a weak area and in time can have the metal actually split and fail along the line.
For proper caulking on any trailer, the old material should be first removed before any new caulking is added. Rigid plastic putty knifes work well, grinding the corners of your old broken screw drivers can produce a tool that will dig out caulking in seams. Cotter key extractors can dig into corners.
Brass, nylon and teflon wheels on a drill can clean off the metal's surface. Scotch Brite in many grades from fine to coarse paint removal can be found at the big box stores. They will clean and polish the metal without damaging its surface. If you have a sander with a hook and loop pad, they will stay in place without being physically attached to the sander.
Be careful and don't inadvertently cut or score the aluminum metal.
gabz
Posted 2012-02-27 2:50 PM (#141508 - in reply to #141489)
1000100100100252525
re: sharp knives and alum...   thanks gard - that's important to know.
r205
Reg. Oct 2011
Posted 2012-02-27 4:07 PM (#141516 - in reply to #141456)
Just completed my trailer seams. I found that after removing all the caulk that I could with a 7 in 1 putty knife, a brass end brush chucked in a variable speed drill turning at very low rpm removed the remainder. A fast rpm would just smear. A nylon brush just smeared the caulking. I assumed because of friction heat. Acetone was used to clean before caulking with sikaflex 221 gray. Working in the shade out of the sun seamed to help. A very thick layer of caulk works best. I also found that bluemagic metal polishing cream did a very good job of polishing the rest of the alumnium trailer. I purchased Bluemagic at a truck stop. I might add that I experimented with many ways before I settled on these two tips. Hope this helps.
MsZoey
Reg. Oct 2004
Posted 2012-02-29 9:47 AM (#141558 - in reply to #141456)
I did caulking on my seams,, than I covered with a seam tape that I purchased at Menards,,, it has a white vinyl back,, top side, with a tar strip underneath,, 5" wide,, very easy to work with,, will never have a leak again... very inexpensive also
bigdreams
Reg. Jul 2010
Posted 2012-03-01 6:06 AM (#141576 - in reply to #141456)
I had to reseal my trailer roof about 2 years ago and after cleaning the old caulk and corrosion off, I used Eternabond. This stuff is great. Just make sure you start at the front and work your way back, to make sure the seams from any cuts face to the rear of the trailer.
horsesnharleys
Reg. Apr 2011
Posted 2012-03-01 7:24 AM (#141577 - in reply to #141558)
What did you chulk with?  was this a steel or Alum trailer?  and what was the name of the tape?
I had someone tell me to use Tar Tape but when I went to the hardware store they didn't know what I was talking about.  I have a steel trailer I want to reseal.  Thanks
horsesnharleys
Reg. Apr 2011
Posted 2012-03-11 8:54 AM (#141924 - in reply to #141456)
bump
To Much Trouble
Reg. Dec 2009
Posted 2012-03-11 12:41 PM (#141931 - in reply to #141924)
Where would one find the Eternabond ?  I too need to do some repairs..it is only in one location at rear of trailer above horse area...I called Sundowner..they use / recommend the Sikflex ( sp?)  but I cannot find it anywhere in my area...  and I just need to do a small area not the whole trailer..Thanks
Posted 2012-03-12 12:41 AM (#141967 - in reply to #141456)
http://www.jamestowndistributors.com/userportal/search_subCategory.do?categoryName=Caulking&category=32&refine=1&page=GRID
