How much can I tow?
Last activity 2012-02-26 8:25 PM
9 replies, 9711 views
balakai
Reg. Feb 2012
Posted 2012-02-25 6:54 PM (#141432)
Subject: How much can I tow?
We have a 2004 Ford F250 SuperCrew 5.4L Triton 4X4 short bed with towing package.  The owner's manual is seriously confusing, but from several websites (including Ford's) I *think* that it will tow up to 13,900 (conventional--does that mean bumper pull?) and 14,200 (fifth wheel--gooseneck?).
Anybody out there have a similar Ford?  What kind of trailer do you pull?
We were looking at aluminum 3 horse bumper pulls (like the Shadow Pro Series), but we found a 2003 Exiss with small living quarters.  I'm waiting to hear back from the seller on the weight of the trailer but comparing it to someone's that I saw today, I'm guessing that it's around 9500-10000 pounds, so it seems like this trailer would put us at the upper end of our towing capacity.
Thoughts/comments/suggestions?
balakai
Reg. Feb 2012
Posted 2012-02-25 7:53 PM (#141434 - in reply to #141432)
Subject: RE: How much can I tow?
Just to clarify, my guess on the weight is with the trailer loaded. ;)  Hopefully the seller will respond quickly with empty trailer weight so that I can figure out for sure if this trailer is an option for us.
Posted 2012-02-26 1:53 AM (#141447 - in reply to #141432)
2004 Ford chart shows 6900# conventional with 3.73 gears and 8400# with 4.10 gears.
Again fifth wheel is rated at 6900# for 3.73's and 8400# for the 4.10's.
GCVWR is 13500# and 15000#.
The numbers you posted look more like the weights for the 6.0 diesel, not the 5.4 with automatic trans. Manual trans numbers are almost identical.
Link to info on page 17..... https://www.fleet.ford.com/showroom/rv_trailer_towing/2004/2004_All.pdf
Edited by retento 2012-02-26 1:57 AM
balakai
Reg. Feb 2012
Posted 2012-02-26 9:36 AM (#141449 - in reply to #141432)
I was looking at page 14 of that brochure.  That chart must represent maximums.
Our truck has the 4.10 axle ration, so I guess we can tow up to 8400 pounds.  I'm a little bummed, because I really love the interior of the living quarters of the trailer I found and I think it's going to be too heavy for our truck.  It's an Exiss XT300 3 horse, which from what I've been able to find online weighs around 4,800 for a trailer without the living quarters conversion.  I'm still waiting to hear back from the seller as to the weight of that specific trailer, but it's not looking good.
Posted 2012-02-26 9:47 AM (#141451 - in reply to #141432)
An Exiss XT 300  with a full Sierra 4' LQ weighs in at ~ 5800#, aprox 950# more than a dressing room model.
balakai
Reg. Feb 2012
Posted 2012-02-26 9:52 AM (#141452 - in reply to #141432)
Thanks, gard--that's what I had guessed but nice to see confirmation of that.
So we could pull an XT300 with dressing room (maxing out our towing capability) but not one with a weekender package.  Oh well.
I really like this trailer... http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=351422
but that looks like a 4' LQ to me.
balakai
Reg. Feb 2012
Posted 2012-02-26 3:29 PM (#141462 - in reply to #141432)
Well, I heard from the seller...she already sold the trailer, but she says that it weighed 4920.
So, we COULD pull that with our Ford.  We'd be pushing the limit of the truck's towing capacity if we take all 3 horses and gear, though--3 horses would mean we could only carry about 500 pounds of tack/water/hay/gear.
Is that doable?  Or do we need to just forget the idea of a GN with weekender?
henrynva
Reg. Nov 2011
Posted 2012-02-26 4:31 PM (#141463 - in reply to #141432)
Add in weight of your truck and all contents + weight of trailer and its contents = not to be more than 15,000 GCVWR would be your answer.
gabz
Posted 2012-02-26 8:16 PM (#141478 - in reply to #141432)
1000100100100252525
Balaki - even though you have a 3/4 ton truck, your towing capacity is actually LESS than my 1/2 ton with the same engine but only the extended cab (NOT crew cab). So our wheel base length is the same, I have a longer bed than you and less truck weight.
 4 wheel drive adds weight to the tow vehicle, as do the extra doors of the crew cabs. The total length of your wheelbase also affects how much you can tow, as do the size of your tires. Believe it or not, smaller wheels - more towing capacity. Of course, there's also more stress on the wheels / studs / tires... so there's that compromise to be considered.  More wheel studs are safer as are larger brakes... but with the trailer having brakes and emergency braking... I don't worry TOO much about that. I don't have too many ginormous hills where I haul. (I would never use this configuration out west .. and would be worried through the Appalachians.)
What ticks me off with these trucks is that you can haul MORE with a weight distribution hitch / bumper pull, then with a 5th wheel or GN!! (and the fact that they sell them with little piss-ant passenger tires)
I have a 5000 pound galvanized steel 3H with 4' short wall GN. I typically haul 1 horse, sometimes 2. I added about 800 pounds with insulation and paneling, and mattress, etc. etc. in DR area. My F150, 4x4, 5.4 litre with... can't remember... 3.75? rear end (not the 4.10) does very well hauling 9500 pounds in 5th wheel configuration and some stuff in the truck. I have a 48 gallon water tank where most people have a rear tack. Having that BEHIND the axle keeps that weight off the tongue / payload - which is what limits the towing capacity of the trucks.
I put my hay, saddle, and that sort of stuff in the front stall; horse in the middle - or middle and back stall.  Hope this helps.
gabz
Posted 2012-02-26 8:25 PM (#141480 - in reply to #141478)
1000100100100252525
When I'm only hauling 1 horse and full water tank - even with 3 or 4 bales of hay and 2 ice chests, I can still accelerate from 55 mph to a higher speed. But again, I'm not hauling in big mountains ...  some long grades sometimes, but that's all.
Mine is 2006 F150.
