Best GN Hitch
Last activity 2012-02-18 10:20 PM
21 replies, 14589 views
barstow
Reg. Feb 2007
Posted 2012-02-17 8:14 AM (#141120)
Subject: Best GN Hitch
Ok, I know I said I was waiting until the fall to purchase my trailer... I can't wait!
So, using some of the advice received here, I am looking at a 2004 Trail-et Westwind (private party, original owner, pristine condition, but having an appraiser look it over just in case). Going with an older, but higher end trailer, rather than a newer, cheaper one. This is Aluminum skin over galvanized steel frame. GVW is 3500#, not sure of the tongue weight, but I have talked to my mechanic as well as a guy at a trailer dealership, and they both agree that my truck will not have any trouble hauling this trailer with two horses loaded.
I have a half-ton 2007 Chevy (classic body style) with the heavy duty rear end, factory equipped bumper pull package. I will be hauling no more than 20 times in 12 months (and that's a generous estimate, probably less). Most of the time my hauls are less than 50 miles round trip, maybe the occasional 300 mile round trip and maybe one or two longer trips.
So, now it's on to the proper hitch. I asked my mechanic if he preferred to purchase it, or did he want me to supply the hitch. He chose the latter.
I want the kind that flips over and allows me the use of my truck bed when not hauling the trailer. A quick search of such things shows prices ranging from under $200 to over $500 for these hitches. I don't want to cheap out when it comes to this, but I also don't want to over pay. Suggestions?
Here's one I came up with using the website's "search by vehicle" option - http://www.reese-hitches.com/products/BW-1059
I did speak to my mechanic about installing the air bags if the tongue weight proves to much, but he does not think that's going to be an issue.
Zipitude
Posted 2012-02-17 8:56 AM (#141121 - in reply to #141120)
Subject: RE: Best GN Hitch
B & W Turnover Ball. Can't beat 'em.
Posted 2012-02-17 8:58 AM (#141122 - in reply to #141120)
Is this somethong simular to what you are looking at?  GVWR  is 7000#, thats 3500# per axle x 2.
Trail-et West Wind (no longer available)
2-horse straight load gooseneck with walk-thru doors and rear ramp
Click for diagram
The Westwind Model is the "gooseneck" version of our popular New Yorker Model. Ample sized stalls and head room, with accessibility to your horses from the rear of the trailer and at the head from the walk-thru doors on both sides. A window at in the walk-thru doors and another at the horse's sides creates the wide-open feeling that horses love. As with all Trail-et Models, features padded sidewalls and center divider, which is completely removable if you prefer a boxstall style stall. The 4' dress area has saddle racks and bridle hooks, and a built-in roof support for an air conditioning unit.
Width:6"Tires:four, ST205/75R15(C) Radial (1,820 lbs.)
Height:7'6"Wheels:four, 15 x 5, five bolt on 4.5" circle
Axles:tandem, 3,500 lbs. each
(7,000 lbs. total)
POPULAR OPTIONS AVAILABLE FOR THE WESTWIND MODEL:
  • Windows in the rear storm doors and the bulkhead wall will create an even more open environment for your horse's comfort.
  • Tubed head divider will increase ventilation and visibility, and will allow "insecure" horses to see each other while in transit.
  • Lower and upper stud dividers are also available.
As for a hitch, my vote is for B&W... http://www.turnoverball.com/products/gooseneck-hitch/turnoverball-gooseneck-hitch
barstow
Reg. Feb 2007
Posted 2012-02-17 9:03 AM (#141123 - in reply to #141122)
Yes, that's the trailer. Here's where I need an education! Does GVWR mean what the axles can withstand, (loaded trailer) Or does GVWR mean the empty weight of the trailer itself? I am sorry to be so lame about this!
Edited by barstow 2012-02-17 9:04 AM
Posted 2012-02-17 9:09 AM (#141124 - in reply to #141123)
Originally written by barstow on 2012-02-17 9:03 AM
  "what the axles can withstand"  3500# each axle for a total of 7000#. That trailer will probably weigh 3500 to 4000# empty, maybe 20% of that on the truck pin, just guessing.
Some of these Hawk/Trail-et dealers should know. Both makes are built nearly alike so the weights should be close.
Phoresic
Reg. May 2010
Posted 2012-02-17 9:15 AM (#141125 - in reply to #141120)
500
I have the B & W Turnover also.  I really like that trailer, btw.
barstow
Reg. Feb 2007
Posted 2012-02-17 10:16 AM (#141128 - in reply to #141125)
ok, so it appears the consensus is the B & W hitch. Thanks for the input and education! Now, let's hope the trailer passes pre-purchase inspection.
barstow
Reg. Feb 2007
Posted 2012-02-17 10:19 AM (#141129 - in reply to #141125)
Thanks Phoresic, I kinda like it too! Hoping the appraiser guy feels the same way ;)
Kay
Posted 2012-02-17 5:51 PM (#141154 - in reply to #141124)
50025
Identical Hawk trailer weighs 4100#
gabz
Posted 2012-02-17 6:22 PM (#141155 - in reply to #141120)
1000100100100252525
Keep in mind that in the northern climates (land of ice & snow), the turnover balls can sometimes become iced in or out.
If you get one where the ball is actually removed, be sure to keep the hole covered.
Good Luck. Nice trailer. Have the brakes checked and adjusted and be sure to install a good brake controller in the truck.
Posted 2012-02-17 7:54 PM (#141162 - in reply to #141120)
Compared to some other hitches, the B+W seems a bit crude in form and finish.  Don't let that fool you.  The B+W is simple and robust in form and function.  The locking is a simple rod through the base of the ball.  Not precision machined parts but also not delicate.  No complex linkages to jam or get out of time.  My B+W is over 10 years old and still working well.
TheOtherHorse
Reg. Mar 2008
Posted 2012-02-17 8:26 PM (#141164 - in reply to #141120)
I love the B&W roll over ball.
barstow
Reg. Feb 2007
Posted 2012-02-17 8:34 PM (#141165 - in reply to #141164)
Great thought on the brake check, thanks! I have a functioning brake controller, can't remember the brand, but it appears to do the job with my BP trailer.
I have ordered my B & W hitch - it's on the way. Thanks to everyone for the advice and recommendations! I will let you know how I make out with the trailer.
Spin Doctor
Reg. Nov 2008
Posted 2012-02-17 9:58 PM (#141168 - in reply to #141120)
Agree to B & W. No other comes close.
One more thing to worry about--make sure the frame on the nose clears the box/tailgate. I like at least 6" but if you can get by with less if careful. Might do search for this on this site as there has been a lot of discussions.
gonzo1066
Reg. Oct 2010
Posted 2012-02-17 10:05 PM (#141170 - in reply to #141120)
I have installed dozens of GN hitches, The ones I installed on my own pickup trucks is the UnaGoose.  STRONG STRONG (tested to 60,000#) and easy install.  The ball is removable from in the bed and will NOT rust up or down like the hitchs with little levers under the wheel well.    Oh yes to those that care, UnaGoose is still made in the USA unlike many of the other name brand hitches. http://www.una-goose.com/
Edited by gonzo1066 2012-02-17 10:07 PM
barstow
Reg. Feb 2007
Posted 2012-02-18 5:39 AM (#141180 - in reply to #141168)
So much to worry about....the clearance would certainly be an important factor to consider!
henrynva
Reg. Nov 2011
Posted 2012-02-18 7:52 AM (#141182 - in reply to #141120)
Unagoose Hitch deserves more attention. Most commonly known is the B&W hitch, but I have had a Unagoose Hitch for 11 years. It is a remarkable piece of engineering, in that it has a stainless steel locking collar with ball bearings. The collar slides the bearings down on the removable ball mount and locks it in. It also has a safety chain plate that snaps down over the ball. There aren't any other holes in the bed for chain mounts. It comes with a cover that fits in the ball hole when the ball mount is not used. Unlike the B&W no rod is needed to lock the ball. It is truly a unique and tough work of American engineering. I didn't realize they were still being made.
gabz
Posted 2012-02-18 8:50 AM (#141184 - in reply to #141180)
1000100100100252525
Barstow. Regarding pickup bed and GN clearance.
If your PU truck is NOT 4-wheel drive, you may not have any trouble. If, however, your PU is 4-wheel drive, it may be an issue. MY driveway is at a slight uphill grade so the combination of turning, plus grade, meant I HAD to go to a new GN trailer rather than a used one, back in 2004. The older ones were not tall enough. I also removed the rails for my tonneau cover.
I also do a the majority of my riding from trail camps, where ground is uneven.
Measure at the center of your truck's rear wheels from ground to the top edge of your pickup box. Add 6". That is the MINIMUM height to the bottom of the Gooseneck area that you will want. Remember too that the coupler can be adjusted, but you do NOT want to run your trailer at a slant because that puts more weight on the rear axle and tires. Rear axle is typically the brake axle.
When trailer is empty, it will obviously, be slightly slanted.
skippyvcu
Reg. May 2006
Posted 2012-02-18 11:21 AM (#141185 - in reply to #141120)
I have never seen the unagoose.  The information states "The chain plate shown above severs two purposes. First, the spring loaded retainers lock around the ball and secure the locking ring to prevent the ball from releasing. The chain plate also provides a secure place to lock your trailer's safety chains without drilling extra holes in the bed of the truck."  If for some reason the chain plate is not locked around the ball, the ball and safety chains can become disconnected from the truck.  With my B&W, if I forget to lock the ball down, the safety chains remain connected to the truck.  My horses are just not worth the risk to save additional holes in the bed.
The towing capacity of either hitch is well above the weight of my 3 horse.
gonzo1066
Reg. Oct 2010
Posted 2012-02-18 12:40 PM (#141186 - in reply to #141185)
Originally written by skippyvcu on 2012-02-18 9:21 AM
It would be extreamly unlikly that the chain plate could come loose. This is a well engeneered and manufactured hitch..   I posted a link to thier page and a accident photo of one of the hitches..        http://www.una-goose.com/testimonial.asp
henrynva
Reg. Nov 2011
Posted 2012-02-18 2:08 PM (#141187 - in reply to #141120)
One last comment about the Unagoose Hitch.  You're not as likely to forget the safety chain plate as much as you could forget to insert the rod in the B&W ball.
Pintolady
Reg. Jan 2012
Posted 2012-02-18 10:20 PM (#141197 - in reply to #141120)
look into the pop up hitches.pull a lever hitch pops up push in the lever hitch goes down into the bed great hitch I have no problems with it...
