Tires are wearing uneven
Last activity 2012-02-21 12:43 PM
7 replies, 5802 views
MsZoey
Reg. Oct 2004
Posted 2012-02-14 5:44 PM (#140965)
Subject: Tires are wearing uneven
I have a 2003 GN Titan Lq, 3 horse,  I noticed this eve that the outside of my tires on the passenger side of trailer,  are somewhat cupped on the outside and just look like they are wearring uneven on both tires,,, the tires on the otherside look okay,,, what's up,,,  solo woman driver....
blt
Reg. Dec 2011
Posted 2012-02-14 7:44 PM (#140974 - in reply to #140965)
Subject: RE: Tires are wearing uneven
I had a similar problem on one of my stock trailers. Turns out the axles were bent a bit. Just took them to frame straightening outfit and got them aligned. End of problem. This would be something to check.
Posted 2012-02-14 10:11 PM (#140984 - in reply to #140965)
Have the alignment checked by a good frame shop. It may be the axles or spindles that are at fault.
gonzo1066
Reg. Oct 2010
Posted 2012-02-14 10:45 PM (#140989 - in reply to #140965)
Not pointing fingers, however most of the time when a trailer has tire problems it is on the right hand side of the rig.   This is caused because the driver ran over a curb or some other object while turning.  Best to get the alignment checked..
Posted 2012-02-14 10:49 PM (#140990 - in reply to #140965)
Check the trailer tire pressures...
The other issue about the passenger side tires is if you do a lot of driving on crowned roads
MsZoey
Reg. Oct 2004
Posted 2012-02-15 8:48 AM (#140996 - in reply to #140965)
thank you!!! I will get it into a shop
MsZoey
Reg. Oct 2004
Posted 2012-02-20 4:17 PM (#141259 - in reply to #140965)
I am so glad I had all of your input, I took my trailer to a very good frame/alignment shop.  They do big semis, etc. several horse and stock trailers.     My trailer frame has been welded to my torsion axles,  with no blocks inbetween the frame and axle, thence when weight in the trailer causes uneven weight on axles,,   this shop said they have seen alot of this in recent years.   My previous trailer had several blow outs,etc. same year of trailer same brand,,,  just not as big,, this one has LQ,, last one had 8' dress. room, both 3 horse slant.      So again thanks for the input,, my trailer will be safe on the road once again
To Much Trouble
Reg. Dec 2009
Posted 2012-02-21 12:43 PM (#141287 - in reply to #140965)
YIPPPEEEE...glad you got the problem addressed...safer for you and your horses !!
