Help, Gooseneck trailer Jack problem
Last activity 2012-02-20 10:44 PM
9 replies, 11015 views
Terrye
Reg. Nov 2010
Posted 2012-01-30 12:26 PM (#140414)
Subject: Help, Gooseneck trailer Jack problem
Hi everyone,
Here are a couple of pics of my gooseneck trailer jack.
It seems a little hard to jack and the leg is crooked.  I am contacting the manufacturer to see if they have advice.
It is a 8x20 foot gooseneck Cimarron.
[IMG]http://i645.photobucket.com/albums/uu177/seejohnnyrun/P10000602.jpg[/IMG]
[IMG]http://i645.photobucket.com/albums/uu177/seejohnnyrun/P10000582.jpg[/IMG]
Thanks
Terry
Terrye
Reg. Nov 2010
Posted 2012-01-30 12:28 PM (#140415 - in reply to #140414)
Subject: RE: Help, Gooseneck trailer Jack problem
Let me try again with the pictures:
<a href="http://s645.photobucket.com/albums/uu177/seejohnnyrun/?action=view&amp;current=P10000582.jpg" target="_blank"><img src="http://i645.photobucket.com/albums/uu177/seejohnnyrun/P10000582.jpg" border="0" alt="Photobucket"></a>
<a href="http://s645.photobucket.com/albums/uu177/seejohnnyrun/?action=view&amp;current=P10000602.jpg" target="_blank"><img src="http://i645.photobucket.com/albums/uu177/seejohnnyrun/P10000602.jpg" border="0" alt="Photobucket"></a>
Terrye
Reg. Nov 2010
Posted 2012-01-30 12:30 PM (#140416 - in reply to #140414)
http://i645.photobucket.com/albums/uu177/seejohnnyrun/DSCN0838.jpg
Posted 2012-01-30 2:21 PM (#140417 - in reply to #140414)
Looks like the jack is DOA and might better be replaced. A bolt on is fairly easy to retrofit, and shouldn't be too difficult to effect a replacement. They are available from several sources, here's one.
http://www.trailerpartsusa.com/products/Heavy_Duty_Square_Tube_Drop_Leg_Jack,TJD-12K-R
Terrye
Reg. Nov 2010
Posted 2012-01-30 5:27 PM (#140425 - in reply to #140414)
ok, thanks Gard.
Terry
Posted 2012-01-30 6:05 PM (#140426 - in reply to #140414)
The trailer jack may not yet be damaged.  It looks like it is over extended.  I would get another jack to lift the trailer.  The idea is to take the load off your trailer jack.  Safety first, use blocks or a jackstand to secure the trailer from falling.  Then, retract the jack by cranking it, while guiding the foot back.  Hopefully, the screw will thread itself back into the nut.
Then, extend the lower foot.  The lever at the lower end of the post releases the foot.  There may be a spring that holds the foot into the jack tube.  Just put your foot on the trailer foot to pull it down.  Use the lever to lock the foot in position.  Then with the foot telescoped out, the jack doesn't have to extend quite so far to lift your trailer.
saltwater redneck
Reg. Apr 2009
Posted 2012-01-31 7:27 AM (#140435 - in reply to #140414)
I agree, looks like you are only lowering the main jack by cranking the handle. You need to lower the leg by releasing the lever and then push the foot down.
henrynva
Reg. Nov 2011
Posted 2012-01-31 8:03 AM (#140436 - in reply to #140414)
I agree that it appears that you have exceeded the length of the jack. You will need to get the weight off the jack before you can a) try to reset the jack leg or b) install a new jack. You could back the truck under the trailer, assumming that you used the jack to get the trailer off the truck and the trailer is still high enough. Then use a small bottle jack set next to the ball to jack up the gooseneck hitch. Or, use a tractor loader to lift the gooseneck and then block up the trailer.
Terrye
Reg. Nov 2010
Posted 2012-02-20 4:17 PM (#141258 - in reply to #140414)
Hi,
Thanks everyone.
Resolved the problem by getting a bigfoot hydraulic jack and a battery installed.  It is the best, and now my lights work inside.  It even has a remote control.
Terry
Posted 2012-02-20 10:44 PM (#141276 - in reply to #140414)
1000500100100100252525
nice
