Lite weight horse trailer
Last activity 2012-02-01 5:10 PM
15 replies, 7882 views
Kayw
Reg. Jan 2012
Posted 2012-01-29 8:36 PM (#140391)
Subject: Lite weight horse trailer
Hello :-) Could anyone tell me what kind of trailer I could pull with a Jeep Liberty? I like the brenderups but they are expensive. Any other trailer work? Just really needs to be a one horse to haul Arabian mare. More for short distances. At the most maybe 100 mile trip but usually for just like 10 miles. Thank you!
Posted 2012-01-29 9:05 PM (#140393 - in reply to #140391)
Subject: RE: Lite weight horse trailer
1000500100100100252525
the real question is how much can your jeep pull? you could do a search on here about brenderup to read what other people have said
Kayw
Reg. Jan 2012
Posted 2012-01-29 9:09 PM (#140394 - in reply to #140391)
I will have to check out what it says in the manual. It is a v6. Thank you I will look. Yes, would love a Brenderup but just too expensive for me unless could find older one.
Posted 2012-01-29 10:59 PM (#140396 - in reply to #140391)
http://www.blueribbontrailers.com/colt-trailers-for-sale.html
Kayw
Reg. Jan 2012
Posted 2012-01-29 11:16 PM (#140398 - in reply to #140391)
The colt horse trainer trailers look nice, sent for information. Ok, so this is what the book says...kind of confusing to me. 2000 lbs max GTW and tongue wt. 200 lbs. then says if using weight distributing hitch. 5000 lbs max GTW and 500 lbs tongue weight. ?? So what could I safely pull? Just need this for one Arabian mare. Thanks again.
Posted 2012-01-30 3:15 AM (#140402 - in reply to #140391)
Here's something that may work, specially if you like a Brenderup.... http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=366782
http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=366232
Kayw
Reg. Jan 2012
Posted 2012-01-30 9:31 AM (#140409 - in reply to #140391)
Thank you for the above information on the trailers. They too look very nice but still quite a bit more than I'm wanting to spend. Thank you though. :-)
Kayw
Reg. Jan 2012
Posted 2012-01-30 2:50 PM (#140419 - in reply to #140396)
The colt trainer is nice but Adam trailer replied and said this trailer might be too much for my Jeep. :-( any other suggestions? :-)
Posted 2012-01-30 3:04 PM (#140420 - in reply to #140391)
There won't be many trailers that aren't too much for your Jeep. Perhaps an older draw bar single? Here's a newer single type:
http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=331553
Kayw
Reg. Jan 2012
Posted 2012-01-30 3:30 PM (#140421 - in reply to #140391)
A one horse trailer would be great. Any other recommendations? Thanks.
Posted 2012-01-31 10:17 PM (#140462 - in reply to #140391)
it looks like a v6 may not be a good thing to tow with it may damage  the jeep. add the weight of the horse and some hay and water and trailer you could be pushing
Kayw
Reg. Jan 2012
Posted 2012-01-31 10:29 PM (#140463 - in reply to #140391)
Even for just short distances? Like 8 miles? I have been interested in the one horse trailer by WW. Thank you for the information, I will keep researching. :-)
AJH
Reg. Nov 2010
Posted 2012-02-01 12:24 PM (#140484 - in reply to #140391)
You didn't give any specifics on your Liberty.  We have a Jeep Liberty Renegade, 4wd V6. My wife uses it to pull a Sundowner Sportsman 2horse aluminum trailer around town. With 2 horses and tack, the trailer is below the listed towing capacity or her Renegade. We only pull it with one horse though, because we have a truck we use when hauling 2 horses. The biggest problem is the short wheelbase. A vehicle about 12" longer would be a plus. A weight distributing hitch would also help.  It can be done, but the Liberty is not the vehicle to use for any long trips.
Posted 2012-02-01 4:34 PM (#140491 - in reply to #140391)
One of these may help with the trailer tongue weight behind that Jeep.... http://www.mrtrailer.com/hellya.htm
Kayw
Reg. Jan 2012
Posted 2012-02-01 4:51 PM (#140493 - in reply to #140391)
Thank you! That hellya hitch helper looks like it would help a lot. :-). Now just got to figure out which trailer. Like the Brenderup still but not the price. :-). The WW one horse is more in my range and with one of these helper things might be just what would work for me. Thanks!
ridingarocky
Reg. Aug 2008
Posted 2012-02-01 5:10 PM (#140495 - in reply to #140391)
500100252525
I pulled a CM Oddessy 2 horse straight load (weight @ 2700 lbs) behind a Chevy Trailblazer with a straight 6 and a tow limit of (I think) @ 5000 lbs. I think if you use a weight distribution bar, you might can pull something like a shadow.. I know the nextrails are light as well. Good luck!
