Tire Pressure Monitoring Systems
Last activity 2012-01-18 12:27 PM
9 replies, 7142 views
d2allen
Reg. Jan 2011
Posted 2012-01-15 2:45 PM (#140041)
Subject: Tire Pressure Monitoring Systems
For Christmas my husband bought me a Tire Pressure Monitoring System (TPMS). It is a Dil brand.What I don't like about it: the tires must be removed to install the sensors, then rebalanced. Plus the dealer tells me that the valve stem opening must be 0.453" for installation. My l.q. trailer is in storage quite a distance away, so it's a hassle to go measure the valve stem opening. My bumper pull trailer has ~ 1/2" valve stem opening, but can't measure it exactly w/o taking the tire off the rim! I'm tempted to return the Dill TPMS and get a Pressure Pro instead. The PP sensors screw onto the valves and the monitor is wireless. Is the PP a good brand? Would it be a mistake to return the Dil unit? I also wonder if any of these TPM S can be used on 2 trailers by switching the monitor from trailer to trailer?I did a search on this forum's on TPMS and found posts from 2010, but nothing recent. I'm interested in reading what others have purchased and how they have worked out over time. Is it possible to use one monitor for multiple trailers?D2ALLEN
captclank
Posted 2012-01-15 3:13 PM (#140042 - in reply to #140041)
Subject: RE: Tire Pressure Monitoring Systems
Been using my Pressure Pro since 2006 without any problems. Batteries lasted 5 1/2 years in the sensors! Nice thing is you can move your sensors from trailer to trailer (keep them in same tire position). They have saved me several times from having problems.
flyinghfarm
Posted 2012-01-15 7:39 PM (#140050 - in reply to #140041)
1000100100
We have had good luck with our pressure pro.  use metal valve stems.  easy and works well.....
Posted 2012-01-15 8:37 PM (#140054 - in reply to #140041)
1000500100100100252525
this is good to know thank you
301duster
Reg. Jan 2009
Posted 2012-01-15 9:49 PM (#140055 - in reply to #140041)
I've had 3 of the pressure pro's kicked off by horses standing at the trailer. They're mounted on steel valve stems to accommodate high pressures. We now take them off when we get where we're going. Have also had some problems with them leaking after so many times on and off. I like the system, but if I had one that could mount on the inside of the rim, I'd sure give it a look. We have younger horses and it makes for an exciting time when they paw one off at 110 psi.
flyinghfarm
Posted 2012-01-16 5:08 PM (#140075 - in reply to #140041)
1000100100
I can imagine!  There she blows!!! More ways than one~!!  Where we go we have usually set up a highline or whatever, and tie as little as possible to the outside of the trailer, and these mules mostly could care less.  I use an air compressor to blow the dirt out of their very thick winter hair when needed and they may be desensitized to the air compressor, but knock a valve stem off and they would get the big eye!
henrynva
Reg. Nov 2011
Posted 2012-01-16 6:44 PM (#140076 - in reply to #140041)
 Sorry to continue a bit off topic, but if you had a video of a horse kicking off a valve stem, it would be priceless and go viral in a flash. We also use the term "Big Eye" to describe these situations. Please post it here first.
kooner
Reg. Jun 2011
Posted 2012-01-17 8:25 AM (#140092 - in reply to #140041)
does the pressure  pro really work? We have an 8 wide trailer and that would be a great add on, but before I plunk down about $500 I would like to hear a little more in put on it.
TSprint2
Reg. Dec 2004
Posted 2012-01-17 8:51 AM (#140094 - in reply to #140041)
tom-tom
Reg. Feb 2008
Posted 2012-01-18 12:27 PM (#140118 - in reply to #140041)
100100100
Truck Systems Technologies.  Bought my system before Thanksgiving and love it.
