Best penetrating oil
Last activity 2012-01-05 11:43 PM
8 replies, 6558 views
BigT
Posted 2011-12-29 7:13 PM (#139724)
Subject: Best penetrating oil
I am trying to free some frozen hinges on the rear curtains on my horse trailer. A while back someone posted about a penetrating product that either has flow or fluid in the name. What is the best penetrating oil product you use?
Posted 2011-12-29 7:43 PM (#139725 - in reply to #139724)
Subject: RE: Best penetrating oil
Originally written by BigT on 2011-12-29 7:13 PMI am trying to free some frozen hinges on the rear curtains on my horse trailer. A while back someone posted about a penetrating product that either has flow or fluid in the name. What is the best penetrating oil product you use?
http://www.kanolabs.com/msn/ 50/50 ACETONE AND atf works best... http://3cyl.com/mraxl/TomsTips/penetrating_oil.htm
Edited by PaulChristenson 2011-12-29 7:46 PM
BigT
Posted 2011-12-29 7:50 PM (#139726 - in reply to #139724)
Thanks Paul for the website, I have seen that website in the past. I found the product that I am looking for in Grainger's online catalog, but I didn't write down the name. It was a little over $10.00.
BigT
Posted 2011-12-29 8:50 PM (#139727 - in reply to #139724)
I found the name of the product....Fluid Film.
Posted 2011-12-29 10:49 PM (#139732 - in reply to #139724)
Be careful using the products on painted surfaces. When I spun wrenches on rusty foreign cars, the best penetrant was old brake fluid mixed 50/50 with Kroil oil. Acetone will thin it for really tight places.
The best lubricant I've found for tight places is synthetic ATF applied with a syringe. Door locks, door, ramp and window hinges are an easy lube, and the fluid won't easily wash out. An application in the fall before storage, keeps everything loose for the Spring. Another shot then usually lasts the summer season.
Posted 2011-12-30 1:41 AM (#139736 - in reply to #139724)
50/50 mix of synthetic ATF and Acetone.... I keep about a half gallon on hand, use some several times a week.
Jeepplr
Reg. Oct 2007
Posted 2012-01-05 4:12 AM (#139846 - in reply to #139724)
For penetrating oil I have used PB Blaster and Thrust.  Both are good Blaster smells better.
Posted 2012-01-05 11:13 AM (#139850 - in reply to #139724)
Kroil ...
rockyrider
Reg. Jun 2004
Posted 2012-01-05 11:43 PM (#139866 - in reply to #139724)
100100100
I second the PB Blaster
