Rain rot
Last activity 2011-12-07 9:54 AM
8 replies, 6715 views
bigfoot
Reg. Dec 2010
Posted 2011-12-03 5:07 PM (#139293)
Subject: Rain rot
I see the beginning signs of rain rot. I have done every treatment I've ever heard of, all at once by the way. The home remedies, and the feed store treatments. My question is do I have to scratch off the little scabs as well? I noticed it last night, and started treatment today. All animals deserve the best treatment we can give them. I have vowed to start stalling them on rainy days. Its not bad yet. Hopefully, I caught it in time.
jackbrat
Posted 2011-12-03 7:15 PM (#139295 - in reply to #139293)
Subject: RE: Rain rot
500100
My mare had something weird on her rump only. Looked more like bites of some kind. Does rain rot mostly show up on the back of the horse or all over or what?
Thanks
Posted 2011-12-03 10:03 PM (#139296 - in reply to #139293)
1000500100100100252525
rain rot starts on the back- rump area and spreads fast. Yes you have to remove the scabs and keep treatment at lease a week after they have gone I used medicated shampoo that I got from the vet but there are stuff out there that will do the job
docgj
Reg. Oct 2009
Posted 2011-12-04 4:28 AM (#139298 - in reply to #139293)
Have you tried baby oil? Last year we had a problem with rain rot and tried everything under the sun to cure it. One of the local Vets suggested using the baby oil. It was the only thing that worked. You just need to apply it liberally to the affected areas. We use disposable gloves as the oil is messy to work with. We just keep the area moist with it. Might take application daily.
docgj
jackbrat
Posted 2011-12-04 9:57 PM (#139325 - in reply to #139293)
500100
My mare didn't get any worse. I think hers were bites of some kind.Maybe even tick bites but didn't see any ticks. I did treat with Betadine. Nothing else has popped up. I did take that sheet she had on off.
ghbb41
Reg. Jul 2007
Posted 2011-12-05 10:20 AM (#139328 - in reply to #139293)
There is a previous thread on rain rot. Betadine is an excellent treatment but you will have to do it more than once. You can leave it on and not wash off. I try to do it three days in a row. Just rub betadine on the affected areas and leave it. Do not pick at the scabs. They can be very painful. After you have treated the affected areas, the scabs will come off as they heal. If you pull on the scabs you will see hair coming out with it. Others on the site here have used listerine, since it has antibacterial affect, it can work too but may burn some. You should see improvement after one treatment and continue to treat unitl it is gone. My horse usually gets it as his winter coat grows along with lots of rainy weather. This year, his was very mild, only had to treated one time.
crowleysridgegirl
Reg. Apr 2005
Posted 2011-12-05 1:39 PM (#139333 - in reply to #139293)
2000500100
Equyss makes an excellent product,called Micro Tek spray.You leave it on,and,the shampoo is good to use prior to the leave on spray.They are pricey products,but,I used them on some dry skin conditions and on my horse's spots from rubbing this summer (bugs were worse than normal,it seemed!) also on "scruff" that my gelding gets on the front of his hind legs from urine splashing.
I will say that last winter I got a big bottle of generic Listerine,and I poured it in a spray bottle and sprayed my horses down on nice days with it.I did notice that come spring,none of them had hardly a trace of rain rot.You might try this,too,barring the shellout for the Equyss products.
brushycreekranch
Reg. Jun 2006
Posted 2011-12-06 8:05 AM (#139355 - in reply to #139293)
500100100100100
I go to Sam's & get the big twin pack bottles of Listerine. It works like a charm for rain rot.
lesliemal
Reg. Sep 2007
Posted 2011-12-07 9:54 AM (#139378 - in reply to #139293)
A solution of 50% rubbing alcohol and 50% white vinegar works really well. Apply with your hands, spray it on or just pour it on. Make sure you saturate the area well. May take a few applications.
