Trailer floor question
Last activity 2011-12-03 8:35 AM
3 replies, 4215 views
rovergirl
Reg. Dec 2011
Posted 2011-12-01 3:04 PM (#139242)
Subject: Trailer floor question
Hello all - I'm new here and have a question.
I've got a two horse trailer - bought it new about six years ago.
It has a wood floor that came from the factory painted.
Since the floor is already painted with some kind of paint (it's just white with a flat finish) I think I'll have to paint it to give it some extra protection right? Point being I couldn't put a water seal on it unless I stripped the paint currently on there off?
If I paint it - would it be ok to put some kind of oil-based paint on it to give it more protection?
I do have good heavy mats over the floor as well and have from the get-go.
Heck - I'm wondering how hard it would be to just replace the floor?
My hubby is very good at stuff like that - this is a CM Dakota trailer - think it's 16' long and 6' wide.
How horrible a job is replacing a wood flooring yourself? Do you use pressure treated wood? Any special tips/things to know if I go that route?
Thanks!
Posted 2011-12-01 10:50 PM (#139256 - in reply to #139242)
Subject: RE: Trailer floor question
1000500100100100252525
I just wanted to say welcome- My question is why do you wont to replace the floor is it bad? to test it use a screwdriver and look for wood rot it you find any then the floor should be replaced, If you replace the floor I would treat the wood first so you can get both side and ends
Flicka123
Reg. Dec 2010
Posted 2011-12-03 7:14 AM (#139278 - in reply to #139242)
First of all, in the past 6 years, how have you maintained your trailer? Have you taken the mats out on a regular basis? Washed it out and let it dry completely before replacing the mats? I pull my mats AT LEAST once every 6 months; in between, I make sure I sweep out the trailer every time I use it. If you have maintained your trailer, you shouldn't have to replace the floor. I would check the wood as mentioned above, make sure no rotting has occurred. Replacing the wood floor is doable, and yes, you should use treated lumber.
ellisor
Reg. Oct 2010
Posted 2011-12-03 8:35 AM (#139282 - in reply to #139278)
White Oak would be good choice for floor replacement.
