Toilet Problem
Last activity 2011-10-07 9:25 PM
4 replies, 4575 views
chattermom
Reg. Sep 2011
Posted 2011-10-06 6:06 PM (#138111)
Subject: Toilet Problem
We just installed a new manual flush toilet but the water doesn't fill the tank. It comes in but extremely slow. We have a good flow of water in the kitchen and bathroom sinks. What could be problem?
calamityj
Reg. Jun 2005
Posted 2011-10-06 11:08 PM (#138118 - in reply to #138111)
Subject: RE: Toilet Problem
500100252525
The water just "rinses" as it flushs and the flapper opens... the tank doesn't fill up like our home toilets. Is it a two pedal model? one is to run the water, the other to open the crapper-flapper....
chattermom
Reg. Sep 2011
Posted 2011-10-07 1:37 PM (#138125 - in reply to #138111)
It just has one. But the water only trickles in, there's about a half inch of water unless you hold the flusher half way down and then a little more water comes in, but it doesn't have a lot of water coming in when you flush. Is that nrmal? There doesn't seem to be enough water coming in to flush much of anything.
threeman
Posted 2011-10-07 3:31 PM (#138126 - in reply to #138125)
10010010025
pickup on the flusher and it will fill the bowl. then you can flush what you want. the 1/2" is just to keep the smell from coming up through the tank.
chattermom
Reg. Sep 2011
Posted 2011-10-07 9:25 PM (#138139 - in reply to #138111)
Thanks, will give it a try.
