Tires cupping on my Sundowner
Last activity 2011-09-21 10:45 AM
8 replies, 8174 views
Fastpony
Reg. Jul 2011
Posted 2011-09-18 9:09 AM (#137626)
Subject: Tires cupping on my Sundowner
What does this mean when all four tires are cupping on the inside? The right rear is the worst but we have been rotating them and they are all getting cupped out. Is this fixable without replacing the axles? Not sure this trailer is worth putting new axles under it. It is still under warranty, would an axle problem be covered?
Posted 2011-09-18 5:42 PM (#137637 - in reply to #137626)
Subject: RE: Tires cupping on my Sundowner
You will have to talk to Sundowner about warranty, But based on my experience of how easy axles are to damage. I would be surprised if bending or damaged axles will be covered under warranty.
When my axles got bent, They destroyed tires, Not just cupping, But total destruction.  I was able to take my trailer into a shop with a large alignment machine designed for large trucks and trailers and they bent the axles back into alignment,.  Gave me a reading before and after showing how much out it was and how far they bent them back.  For me this was a last effort at repair before replacing the axles.
If you are having ongoing tire problems, I would find a shop in your area that can check the alignment of your axles. It cost me $80. Pretty reasonable cost to determine IF your axle is bad
laurie
Reg. Jun 2004
Posted 2011-09-19 10:32 AM (#137658 - in reply to #137626)
10010010010025
I would find a reputable trailer axle and alignment shop and have them look at it.
whitewood
Reg. Jun 2009
Posted 2011-09-19 11:06 AM (#137659 - in reply to #137626)
Just go to an alignment shop, its an easy fix, not some place that wants to sell you new axels.
Fastpony
Reg. Jul 2011
Posted 2011-09-19 11:17 PM (#137689 - in reply to #137626)
Thanks, I had no idea they could align trailer axles.50
Posted 2011-09-20 8:12 PM (#137725 - in reply to #137626)
Originally written by Fastpony on 2011-09-18 9:09 AM
The first thing to do is confirm that the tires are FULLY inflated...if they are then its off to have the axles checked...
Posted 2011-09-21 7:23 AM (#137734 - in reply to #137626)
Along with what Paul said about inflation.... What weight and speed are these tires rated? What is your weight per axle/wheel?  How old are these tires? Sure you don't have some belts seperating? Some of the coarser, mud and snow looking tread Chinese tires tend to cup out also... The smother, straighter, less grooves in the tread, the less chance of cupping and gouging. Look at the G614RST, thick heavy tread rubber with very few shallow grooves and sipes, no issues with cupping.
 Get it fixed soon, nothing much worse than a flat on the right rear with nowhere to pull over to make a change.....
Edited by retento 2011-09-21 7:25 AM
Posted 2011-09-21 10:37 AM (#137742 - in reply to #137626)
The alignment shop I took mine to, Said it is a real common occurance on boat trailers. Their owners seem to back the trailer over curbs more often than owners of other trailers.  And boat trailers have a tendency to be lighter duty than heavy horse or equipment trailers. He said he can usually straighten an axle 2-3 times before it needs to be replaced.
Horse trailers can be a little harder to adjust because of the floor in the trailer There is not as much room between the axle and floor to attach the rams needed or to get the proper angle to bend the axle back straight.
RTSmith
Posted 2011-09-21 10:45 AM (#137743 - in reply to #137626)
Remember- this is a Sundowner in question. It will likely have torsion axles that are not intended to be straightened. On a torsion axle, it is the spindle or swing arm that bends- but you are bending the axle tube to try and correct it. Two "wrongs" don't make a right. It might look good on the alignment print out, but it won't be correct. The only proper repair for a bent torsion axle is replacement of the beam. At least according to the folks who design and build them.
