AC
Last activity 2011-08-25 10:33 PM
2 replies, 4604 views
Amp
Reg. Aug 2011
Posted 2011-08-25 10:54 AM (#137006)
Subject: AC
What is the best AC to use for my LQ upgrade. I will need a heat strip in mine. I will use my trailer mostly with a 30 amp hook up but i have a generator too.
Posted 2011-08-25 7:31 PM (#137017 - in reply to #137006)
Subject: RE: AC
I would stay away from the Duo-Therm Brisk Air... Get the 13.5 Coleman Powersaver with heat strips..... http://www.pplmotorhomes.com/parts/rv-air-conditioners/coleman-mach-III-pwr-savr.htm
http://www.pplmotorhomes.com/parts/rv-air-conditioners/mach-III-ps-data.pdf
Carrier build a fine unit until they quit a year or so ago.
Edited by retento 2011-08-25 7:33 PM
Posted 2011-08-25 10:33 PM (#137025 - in reply to #137006)
Subject: RE: AC
The heat strips on the AC units are pretty much worthless, at a considerable optional pricing. The best aux heater is a $25 ceramic unit available from many sources. One can easily heat a 13' LQ at below freezing outside temps. They usually draw ~13 amps, are thermostatically controlled, and are far quieter than the main AC fans.
I have two Duotherm AC units, and both work flawlessly into a decade of usage for each. Their strip heaters, however, only serve to warm up a warm space.
