exterior loading lights
Last activity 2011-08-20 9:18 PM
11 replies, 18630 views
clamb
Reg. Aug 2011
Posted 2011-08-14 5:14 PM (#136698)
Subject: exterior loading lights
Hi
I have a Platinum trailer and can not get the exterior loading lamps to work.  I have flipped the swtiches but nothing.  The interior lights for the horses do not come on either.  I don't have an owners manual (bought it used), and all the lights for the liviing quarters work just fine.
Any ideas?
kooner
Reg. Jun 2011
Posted 2011-08-14 6:24 PM (#136699 - in reply to #136698)
Subject: RE: exterior loading lights
1st thing to do is use a voltage tester and make sure you have power to the switch, if not I would look at the plug on the trailer, some times things are not wired like they should be, the main thing is to eleminate the simple things first.
Posted 2011-08-14 10:30 PM (#136707 - in reply to #136698)
Some trailers have individual light circuits that are powered by the towing vehicle through the B+ wiring. Depending on the vehicle, it may or may not power the trailers' circuits unless it's running. Make sure the plug is installed, and you have power to the trailer.
docgj
Reg. Oct 2009
Posted 2011-08-15 6:49 AM (#136709 - in reply to #136698)
What are you using for a tow vehicle? I discovered that the newer (2009) Ford's don't have all the fuses installed from the factory. The one that was missing in mine was the one that powered the loading lights.
docgj
Posted 2011-08-15 7:30 AM (#136710 - in reply to #136698)
1st make sure you are either connected to the tow vehicle and it is on, or that you have a battery on the trailer that is fully charged and providing power.
2nd Check to see that you are getting power to the switch.  ( voltmeter or test light. )
3rd. See if you are getting power THRU the switch.  The switches in my Logan coach got dust in them and I had to flush them out to get them working. ( sprayed lots of WD40 over the switch)
4th Most trailer lights use the trailer as the ground. So at the light make sure the light's  ground has a good connection. If you are having problems with multiple lights this would be one of the lessor possibilities.  The chances of loosing the ground on all your lights at the same time is smaller than the power not coming thru.
clamb
Reg. Aug 2011
Posted 2011-08-15 8:28 AM (#136711 - in reply to #136698)
Thanks for all the great suggestions. I am pulling with a Ford F250 diesel. I connected the pickup to the trailer and started it up...still no lights. Maybe the fuse problem is in the pickup? The guard lights and blinkers are all working when connected. Really a puzzle!
Carmelita
docgj
Reg. Oct 2009
Posted 2011-08-15 9:57 AM (#136714 - in reply to #136698)
Thats where my fuse problem was. In the truck. Is it a newer F250?
docgj
Terrye
Reg. Nov 2010
Posted 2011-08-15 12:10 PM (#136716 - in reply to #136698)
Fords only power the exterior lights when the truck is running. Try that first.
Terry
BlazingCreekBar
Reg. Nov 2008
Posted 2011-08-15 5:00 PM (#136721 - in reply to #136698)
Check your fuse panel in the LQ.  I had the same issue it was a fuse in the LQ.
Basically your loading lights and horse interior are hooked up to operate when disconnected from the tow vehicle.
Look for a fuse marked charge line.
Edited by BlazingCreekBar 2011-08-15 5:01 PM
Posted 2011-08-15 6:57 PM (#136724 - in reply to #136698)
Did you do what kooner told you to do?The load lights on many trailers come from the TRAILER'S battery...and work whether you are hitched to the tow vehicle or not...You should also get a continuity tester to see if you have broken wires...
Edited by PaulChristenson 2011-08-15 6:59 PM
ghbb41
Reg. Jul 2007
Posted 2011-08-16 11:07 AM (#136734 - in reply to #136698)
I have two different horse trailers and pull with a 2009 Ford F-250 disel. The exterior light come on with my keifer wheather it is hooked up or not, but I had that done at the dealer ship. The other trailer lights do not come on unless it is hooked to the truck, my truck does not have to be running but the truck switch has to be in the 'on' position. The interior lights on the Keifer have individual swiches and they have to be in the 'on' position to come on even with the toggle switch on the out side. My older trailer interior lights do not come on unless hooked to truck and do not have individual switches. Every year, I have to take the covers off, clean out the little boxes, clean the ends of the bulbs, then I have lights. Between age and dust, they don't always work. I have had the wiring to wear though on the outside just where it enters the lgiht boxes and I just had to put it back togather. The voltage tester thing is a good idea too as this has also been an issue. I usually hook up at the beginning of riding season and begin at rear of my older trailer and work forward to find the problem.
CTRider
Reg. Sep 2009
Posted 2011-08-20 9:18 PM (#136830 - in reply to #136698)
10010010025
We had this same problem. We discovered it was a fuse located in the battery box of the trailer.
