Plexiglass Inserts Vibrating???
Last activity 2011-08-11 10:09 AM
3 replies, 5743 views
tralbos
Reg. May 2008
Posted 2011-08-10 10:04 AM (#136599)
Subject: Plexiglass Inserts Vibrating???
I have a trailer that has plexiglass inserts. In the wind sitting still or driving down the road the plexiglass inserts rattle and vibrate. Is there some type of easy fix i can do that will eliminate the looseness???
Posted 2011-08-10 10:22 AM (#136600 - in reply to #136599)
Subject: RE: Plexiglass Inserts Vibrating???
Apply a dab of silicone caulk about every foot or so to the edges. If you want to remove the panels, the caulk can be easily cut with a utility knife.
tralbos
Reg. May 2008
Posted 2011-08-10 2:24 PM (#136609 - in reply to #136599)
Good idea... Thanks
Posted 2011-08-11 10:09 AM (#136632 - in reply to #136599)
1000500100100100252525
a piece of siya form will also work and no cutting needed
