F-150 pulling a gooseneck
Last activity 2011-08-31 2:53 PM
16 replies, 21506 views
Ia Kidd
Reg. Aug 2011
Posted 2011-08-05 4:06 PM (#136489)
Subject: F-150 pulling a gooseneck
I have a 2010 F-150 FX4, supercrew shortbox.  It has a trailer tow package and a 5.4 V8 motor.  I am looking at purchising a Sundowner 6906 2 horse.  I have been told I can tow it with my shortbox with a B&W hitch and possibly a 6 inch extension...
Need your thoughts and expertise.
horsey1
Reg. Dec 2004
Posted 2011-08-05 4:11 PM (#136490 - in reply to #136489)
Subject: RE: F-150 pulling a gooseneck
There will be many chime in here. My 1 question- does it have an escape door? If so, the axles will be at the back and it will have a higher than normal tongue weight factor.
Edited by horsey1 2011-08-05 4:13 PM
Ia Kidd
Reg. Aug 2011
Posted 2011-08-05 4:57 PM (#136492 - in reply to #136490)
No escape door....
adeberti
Reg. May 2007
Posted 2011-08-05 5:11 PM (#136493 - in reply to #136489)
look at the nose of the GN and make sure you have room to make turns.If you have the 5'5 ft box, you are prob in trouble, with a 6'5 ft box you should have more play room.B&W only makes a 4inch extension, and i think curt makes a 5": make sure all parts are compatible.The also make extension for the actual trailer and they will push the trailer back, but won't give you and extra room at 90degrees or so.
BigT
Posted 2011-08-05 7:58 PM (#136497 - in reply to #136489)
Here is a web page that has some been there.. done that experienceshttp://www.fordf150.net/forums/viewtopic.php?t=65867
Ia Kidd
Reg. Aug 2011
Posted 2011-08-07 10:29 PM (#136529 - in reply to #136493)
B&W makes a 10' pull back attachment that attaches to the trailer itself.  Still trying to decide on the 8906 RS Sundowner.  Several dealers have stated that they have sold several to pull with the shortbox F-150.
calamityj
Reg. Jun 2005
Posted 2011-08-08 9:03 AM (#136538 - in reply to #136489)
500100252525
If in doubt, don't do it. You need to upgrade your truck or downgrade a trailer. Good luck.
Posted 2011-08-08 10:31 AM (#136541 - in reply to #136489)
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=15741
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=15401&posts=15
SweetWillyB
Reg. Apr 2011
Posted 2011-08-08 1:45 PM (#136552 - in reply to #136541)
SweetWillyB
Reg. Apr 2011
Posted 2011-08-08 1:48 PM (#136553 - in reply to #136552)
Have you seen the ads for the Shadow Stablemate Living Quarter? They have a 3 horse with a 9' shortwall and a slide, that is towed with a 2011 F150 with a tow package.
Ia Kidd
Reg. Aug 2011
Posted 2011-08-08 1:59 PM (#136554 - in reply to #136553)
Yes, I saw the ad.  Was just wodering about turning...looks great in a photo.
doughbelly
Reg. Mar 2009
Posted 2011-08-08 2:08 PM (#136555 - in reply to #136489)
pulling is one thing stopping another
SweetWillyB
Reg. Apr 2011
Posted 2011-08-08 2:28 PM (#136556 - in reply to #136555)
You can get any gooseneck into your cab if you try hard enough. With the B&W adjustable hitch and the Stablemate Living Quarter being six wide, you shouldn't have any problems.
Flicka123
Reg. Dec 2010
Posted 2011-08-28 6:42 PM (#137073 - in reply to #136489)
I pull my 2006 Sundowner 2H straightload with a F150. I had a 2010 F150 and a month ago traded up to a 2011 F150 with the Ecoboost engine and tow package. I am so pleased with how this new truck pulls, compared to my last truck with a V8. This truck has a stiffer suspension, although I do plan to add Timbrens to it. Had them on my last truck, and it definitely improves the ride stability. I have a 6.5' bed on my truck, and usually don't have any problems with interference with the gooseneck. Have a Primus brake controller and don't have any problems stopping, and trailer doesn't push me. If you have a 5.5' box, I do believe I would get the extension.....
SeanP
Reg. Aug 2011
Posted 2011-08-29 9:35 AM (#137088 - in reply to #136489)
Hello I work at the Shadow Trailer factory here in Williston Florida, we make many trailer that can be pulled with your truck. Bumper pulls and Goosnecks. We even make a Liveing Quarter trailer that can be pulled with a 3/4 ton pick up.
Ia Kidd
Reg. Aug 2011
Posted 2011-08-30 12:05 PM (#137132 - in reply to #137088)
I thought the new Shadow gooseneck with LQtrs was designed to be pulled by a 1/2 ton truck.  That is what all the ads show.
Is this true?
SeanP
Reg. Aug 2011
Posted 2011-08-31 2:53 PM (#137149 - in reply to #136489)
It is true. I wrote the wrong numbers down before. The 1/2 ton truck is the one in the ad for the Stablemate Liveing Quarter.
