One horse in 3H slant...which stall?
Last activity 2011-07-26 9:42 AM
7 replies, 5365 views
brendaclemens
Reg. Jan 2009
Posted 2011-07-25 11:27 AM (#136057)
Subject: One horse in 3H slant...which stall?
I carry hay & extras in the first stall...which stall would you load your one horse in & why.
Thank you!
Brenda
doughbelly
Reg. Mar 2009
Posted 2011-07-25 12:18 PM (#136062 - in reply to #136057)
Subject: RE: One horse in 3H slant...which stall?
Wouldn't think it would really matter that much. And if it did it would depend on the individual trailer as far as axel placement, if you have mangers and how they are loaded and rear tack and how much weight you have in it.
horsey1
Reg. Dec 2004
Posted 2011-07-25 12:48 PM (#136065 - in reply to #136057)
And very important- gooseneck or bumper pull??
Posted 2011-07-25 12:57 PM (#136066 - in reply to #136057)
In a GN trailer, the rear stall works well, while using the front stalls for storage. In a BP trailer, the better loading is which ever stall is directly over the axles. This varies from manufacturer to manufacturer. Some center stalls will be over the axles, some with longer dressing rooms will not be centered. Depending on the trailer's configuration, always using the front stall can drastically increase the tongue weight, whilst only using the rear stall can unload the hitch weight, causing poor tracking.
Gn trailers are not as sensitive to specific loading as BP trailers. Generally a 3H BP trailer will allow you to vary the loading, depending on the number of horses you are carrying. This can allow a very properly weighted trailer, that both tracks well and has a minimal amount of tongue weight. Many people assume a 3H BP trailer will have a higher tongue weight than a 2H BP trailer, while just the opposite is often the case.
brendaclemens
Reg. Jan 2009
Posted 2011-07-25 1:23 PM (#136068 - in reply to #136066)
Mine is GN w/10'lq & 3 stalls...pulling with Ram 3500 dually.
nd deb
Reg. Apr 2004
Posted 2011-07-25 1:44 PM (#136069 - in reply to #136057)
My slant trailer has a straight wall which makes the first stall pie shaped.. I use it mostly for a mid tack/mud room but able to use it for a horse if needed... If I haul one horse I usually place it in the 2nd stall...
whitewood
Reg. Jun 2009
Posted 2011-07-26 9:38 AM (#136095 - in reply to #136057)
the roughest ride is the back stall behind the axels on a slant load. Just hop back there and have someone you trust give you a ride down the hwy at 65. Everybody should before they can haul a horse.
brendaclemens
Reg. Jan 2009
Posted 2011-07-26 9:42 AM (#136096 - in reply to #136095)
I think I'll stick with the second stall. Thanks for all of the replies :)
