Lights suddenly not working?
Last activity 2011-07-17 7:23 AM
3 replies, 3846 views
jspt2003
Reg. Jul 2011
Posted 2011-07-16 7:33 PM (#135728)
Subject: Lights suddenly not working?
....why is it so difficult getting a trailer set up properly?
Long story short, got new brake box controller. Had disconnection upfront in truck with one wire, got that all sorted out. Truck correctly wired and ready to go on its' end. Went to go hook up to our trailer had right side only on trailer lights working (brake and turn signal) nothing from left. All lights on truck working fine. But now we have nothing. Tried hooking our friends truck up to it, and nothing. While at the trailer place we hooked our truck up to an RV and the connection was fine. So it's def on the trailer end. With both our truck and the friends truck the brake box controller wasn't even lighting up. Again when he had ours to the RV the green light came on right away. And when our friend plugged into his 2 horse he had power right away.
Had the trailer inspected less than month ago and everything worked FINE. How does it go to crap just like that?! Haven't used it since the inspection.
IDEAS?
skippyvcu
Reg. May 2006
Posted 2011-07-16 7:59 PM (#135729 - in reply to #135728)
Subject: RE: Lights suddenly not working?
If you have no lights or brakes, I would suspect that there is a grounding problem. To test, connect a jumper cable from the truck frame to the trailer frame.
Posted 2011-07-16 9:09 PM (#135733 - in reply to #135728)
First...Open the plug and check for wires pulled from mounts.
Rob77
Reg. Jul 2011
Posted 2011-07-17 7:23 AM (#135741 - in reply to #135729)
As Skippy says you have lost your ground, check with a meter at a light in the rear and come forward to the connector on the truck---the bad ground will show up. If all else fails return at to the installer.
