Where can I get a jack for my trailer?
Last activity 2011-07-17 2:47 PM
15 replies, 6603 views
mandyruth2980
Reg. May 2011
Posted 2011-07-16 12:04 PM (#135709)
Subject: Where can I get a jack for my trailer?
Hi y'all! I just bought a 2000 Elite with a 7 1/2 ft SW. I think it has a 2 speed manual jack & it takes "super power" strength to raise/lower it! We have greased it & everything but it is still so hard to use! I know electric jacks & hydraulic jack are so expensive & I was wondering if anyone knows of a place where I can get a used one, maybe off a wrecked trailer or something. I would maybe also be interested in a new manual jack if the other used ones are too expensive. If you have any suggestions~please let me know! Thanks a bunch!!
siseley
Reg. Jul 2006
Posted 2011-07-16 12:12 PM (#135711 - in reply to #135709)
Subject: RE: Where can I get a jack for my trailer?
When we replaced ours, we got it from a place called adventurerv.net They had one for our needs, and shipped it to us quickly.4000 lb capacity, and it was easy to install. About $350 dollars.
mandyruth2980
Reg. May 2011
Posted 2011-07-16 12:18 PM (#135712 - in reply to #135709)
Was it manual, electric, or hydraulic?
siseley
Reg. Jul 2006
Posted 2011-07-16 12:32 PM (#135715 - in reply to #135709)
Ours is electric, and is called an "VIP".the catalogue number is; 94-0116, and it has 24" of travel.it is perfect for toy haulers, and high tow vehicles. Has a built in light for night time, and easy switches for operation.
mandyruth2980
Reg. May 2011
Posted 2011-07-16 12:40 PM (#135716 - in reply to #135709)
Thanks for the info! I will need one with more than 4000 lb capacity but I will check that website!!
Posted 2011-07-16 2:26 PM (#135721 - in reply to #135709)
http://www.bigfootleveler.com/trailerjacks/horsetrailers.php
blackcows
Posted 2011-07-17 6:34 AM (#135739 - in reply to #135709)
100100100100252525
I've been watching eBay, CL, forums...you name it, for years and have had zero luck finding a used electric or hyd jack so if you find one you'd better grab it.
LonghornTRL
Reg. Mar 2008
Posted 2011-07-17 8:36 AM (#135749 - in reply to #135709)
Try your local if you have one Tractor Supply. They sell the Bulldog jacks rated for 12,000 lbs
mandyruth2980
Reg. May 2011
Posted 2011-07-17 8:48 AM (#135750 - in reply to #135709)
Thanks for all the info!!
wyndancer
Reg. Apr 2007
Posted 2011-07-17 9:46 AM (#135751 - in reply to #135709)
"I think it has a 2 speed manual jack & it takes "super power" strength to raise/lower it!"
You need to figure out if it is a 2 speed jack, because when those 2 speed are in high gear it takes super human strength to lift much...but it does go fast if you've got the arms! When they are shifted to low gear they crank pretty easy, but it takes alot of turns to get anywhere. So when you have the jack handle attached, see if you can pull the crank, and the shaft it's attached to, towards you to shift to low gear....try then. Most 2 speed jacks are pretty big..like the one on the right.
brendaclemens
Reg. Jan 2009
Posted 2011-07-17 10:37 AM (#135753 - in reply to #135709)
I have an Equalizer Hydraulic for sale...my 02 Elite w/10'8 LQ burned (in the rear end) saved the jack & new trailer already had one...it is only 2 yrs old $500+ shipping ...was $900 new. Perfect condition.
http://equalizersystems.com/Horse_Hydraulic.asp
316-648-1874
mandyruth2980
Reg. May 2011
Posted 2011-07-17 11:47 AM (#135755 - in reply to #135709)
Oh wow! Where are you located?
brendaclemens
Reg. Jan 2009
Posted 2011-07-17 12:23 PM (#135757 - in reply to #135755)
I am in SE Kansas
brendaclemens
Reg. Jan 2009
Posted 2011-07-17 12:24 PM (#135758 - in reply to #135757)
Will throw in the big marine battery if you come pick it up, but I won't ship the battery.
mandyruth2980
Reg. May 2011
Posted 2011-07-17 12:38 PM (#135759 - in reply to #135709)
I'm in SE Texas~what do you think the shipping would cost? Just a estimate.
brendaclemens
Reg. Jan 2009
Posted 2011-07-17 2:47 PM (#135765 - in reply to #135759)
$40-$80...just guessing
