Tankless Hot Water Heaters?
Last activity 2011-08-27 7:25 AM
13 replies, 16211 views
3canstorun
Reg. Jul 2011
Posted 2011-07-15 10:58 AM (#135666)
Subject: Tankless Hot Water Heaters?
Does anyone have any opinions on these for use in the LQ's?  I have seen them advertised and wonder if they are a good idea?
wyndancer
Reg. Apr 2007
Posted 2011-07-15 1:14 PM (#135672 - in reply to #135666)
Subject: RE: Tankless Hot Water Heaters?
The LP fired one? They are expensive with a capital E!
hornet
Posted 2011-07-16 9:22 AM (#135707 - in reply to #135666)
I looked into them as well a few years back when our tank water heater failed. But at $700 I'll just keep doing what I've been doing. It takes thinking ahead but, we don't leave the water heater on all the time. It only takes about 30 minutes for the water heater to heat up.
PDGx
Reg. Jul 2011
Posted 2011-07-16 9:59 PM (#135735 - in reply to #135666)
Take a look at sportsmansguide.com and search for tankless water heater. There are two different sizes. We have the smaller one in the barn to heat water for washing in winter. The larger would be better but the smaller one would work for showers. PDGx
bigfoot
Reg. Dec 2010
Posted 2011-07-17 1:36 AM (#135738 - in reply to #135666)
I have had two electric on demand water heaters. They worked great the only down side was if you were primitive camping. They also pull plenty of current. Better turn off the ac if you are hooked to a 30 amp breaker.
brushycreekranch
Reg. Jun 2006
Posted 2011-07-17 7:31 AM (#135743 - in reply to #135666)
500100100100100
I have a propane fired tankless in my weekender. It was $149 from camping world and all you add is a water source and any size of propane canister. I prefer to use the little one.
Zipitude
Posted 2011-07-18 9:29 PM (#135808 - in reply to #135666)
I have the Eccotemp, which is probably the same one brushycreek is mentioning. Got mine at Cmping World as well. It's awesome! Never had any issues with it. Works great!
3canstorun
Reg. Jul 2011
Posted 2011-07-19 10:18 AM (#135825 - in reply to #135666)
I found a Bosch one - and it will work.  It is electric. http://www.google.com/products/catalog?q=bosch+electric+tankless+water+heater&hl=en&prmd=ivns&bav=on.2,or.r_gc.r_pw.&biw=1280&bih=852&wrapid=tlif131108828331210&um=1&ie=UTF-8&tbm=shop&cid=7475524284259096858&sa=X&ei=JKAlTui2OIXPgAfcvqzvBQ&ved=0CGsQ8wIwAg#
 After reading about the gas ones, do you use them inside the LQ?
brushycreekranch
Reg. Jun 2006
Posted 2011-07-19 1:11 PM (#135830 - in reply to #135666)
500100100100100
My weekender is a cowboy shower in the first stall. A lot of folks wrote reviews on this propane water heater and said they are replacing their RV water heaters with them instead of the OEM Dometic or Surburban. They say they like them much better. When my big LQ needed a new water heater recently, I did consider it. But, due to the high value of the trailer, I decided to keep it exactly as it was and paid $1000 for a new OEM replacement.
doughbelly
Reg. Mar 2009
Posted 2011-07-19 1:17 PM (#135831 - in reply to #135666)
I have installed around 30 Rinnina's in homes and they have performed flawlessley. I can purchase a smaller unit for around $500 that will still run three or four horse trailers. If ours ever goes out it will be replaced with one.
doughbelly
Reg. Mar 2009
Posted 2011-07-19 1:24 PM (#135832 - in reply to #135666)
The only use I have found for an electric on demand unit would be at the point of use where you have a long run from your main hot water supply.  It would take a pretty large electric unit and generator to supply enough hot water even for a shower.
Zipitude
Posted 2011-07-20 11:54 AM (#135876 - in reply to #135666)
I use mine in the horse area. I have a cowboy shower in the stud stall.
Amp
Reg. Aug 2011
Posted 2011-08-25 10:49 AM (#137005 - in reply to #135666)
So the best one is a gas waterless? Did I read right camping world has them for $149? How do they vent the pilot light?
tr0y
Reg. Mar 2009
Posted 2011-08-27 7:25 AM (#137042 - in reply to #135666)
Have a look here,
Ecotemp @ amazon.com
http://www.amazon.com/Eccotemp-L5-Portable-Camp-Shower/dp/B00388PME...
solid customer service they call you back, are helpful, you can permanent mount it if you want, and this thing gets rave reviews, I have used one and am ordering one on next payday for my new 1st stall shower
