Water Tank Questions
Last activity 2011-07-17 4:36 PM
6 replies, 5287 views
BJWells
Reg. Jul 2011
Posted 2011-07-15 9:46 AM (#135661)
Subject: Water Tank Questions
We have a Elite LQ with a hay rack up top...the hay rack houses our generator, spare tire and a 40 gallon water tank for the horses.
The water tank is the heavy plastic kind.... and is strapped down but not covered...I am running into a problem where here in NC it is so hot in the summer that the water in my tank is getting super hot.....IS there anything that I can buy/or have made that isnt going to cost a arm and leg to help reflect some of the heat from the sun away from the tank and help keep the water a bit cooler? Moving the tank is not an option...
someone recommend using duct tape like they use for HVAC installation and another recommended buying a reflective visor that people use for their car's front window...
remember that it has to hold up to interstate travel and going 70+ mph and I dont want it to look ghetto.
We rodeo so I need that tank as we never know what kind of situation we will run into on the road where we need water...
Any ideas?
Posted 2011-07-16 12:06 AM (#135698 - in reply to #135661)
Subject: RE: Water Tank Questions
Welcome to the forum.
The best I would think is a cover. Can you fasten a sheet of metal over the tank... say from the toop edges of the hay rack? The metal would also help reduce wind drag. It would insulate best with an air space between the metal and the tank. Doesn't have to be a large space. 1/2 inch will do.
horsey1
Reg. Dec 2004
Posted 2011-07-16 7:58 AM (#135704 - in reply to #135661)
What color is the tank now? If it is anything other than a white or silver, I'd think of painting it.
sdlepalpm
Reg. Nov 2008
Posted 2011-07-17 2:02 PM (#135762 - in reply to #135661)
It would be hard to cover the tank up when hauling I would think.  We just keep a tarp on ours when we are not traveling.  It is a nosiunce going up and down the ladder to do so, but it works.
SRWilson
Reg. Jul 2010
Posted 2011-07-17 3:12 PM (#135766 - in reply to #135661)
This might look a little silly but try this insulation and use the Duct tape (silver aluminium air duct type) both are on this link. I used this insulation on the front curved nose of my Exiss and it keeps the heat out in the summer and in in the winter just great. It sort of looks like bubble wrap only its foil material.http://www.homedepot.com/webapp/wcs/stores/servlet/Search?keyword=foil+isulation&selectedCatgry=SEARCH+ALL&langId=-1&storeId=10051&catalogId=10053Sean
brendaclemens
Reg. Jan 2009
Posted 2011-07-17 4:35 PM (#135769 - in reply to #135766)
That is what I was going to suggest...it works great for a lot of applications & is very durable. You could warp it in the bubble insul (I think it is called reflective insul) and then just use your tie downs to hold it instead of duct tape.
brendaclemens
Reg. Jan 2009
Posted 2011-07-17 4:36 PM (#135770 - in reply to #135766)
