Gooseneck hits corner of truck on hills
Last activity 2011-06-24 10:15 AM
6 replies, 6420 views
alexandra77
Reg. Jun 2011
Posted 2011-06-22 3:28 PM (#135050)
Subject: Gooseneck hits corner of truck on hills
Have a hilly driveway to go into and out of with a sharp curve coming in. Normally I can avoid the hitting problem by keeping the truck and trailer exactly straight, but I can't do that here without hitting a tree. I barely make contact but it is enough to crush the corner of the truck (where the side and the tailgate meet) a tiny bit. I have read about raising the ball, etc. but right now the trailer is perfectly level and I don't want my horses standing on a hill. Does anyone simply sell steel caps that I could put on the truck corners to protect them from damage? Anything like that?No, the gooseneck is not adjustable. This is an old trailer that I am driving for a job.
Posted 2011-06-22 8:01 PM (#135053 - in reply to #135050)
Subject: RE: Gooseneck hits corner of truck on hills
Just raise the gooseneck hitch one hole.  It won't affect the horses.
Raising the front end 2"  is spread over the distance beween the ball and axles. So in any given spot, You've only raised a horse 3/8 to 1/2". Depending on the length of your trailer.
kentuckyrain
Reg. Apr 2008
Posted 2011-06-22 8:42 PM (#135055 - in reply to #135053)
Originally written by Painted Horse on 2011-06-22 9:01 PM
I think the op said the gooseneck was not adjustable..... So can that be changed out to an adjustable one?
Edited by kentuckyrain 2011-06-22 8:44 PM
Posted 2011-06-23 12:06 AM (#135060 - in reply to #135050)
Whoops my bad.  Didn't pay attention to that line.
That being the case, I'd look for a taller ball.
jim bob
Reg. Jan 2008
Posted 2011-06-23 9:46 AM (#135073 - in reply to #135050)
We have changed stationary couplers to adjustable by cutting the actual coupler off of the tube, and than inserting an adjustable into it.  It usually means drilling holes for a pin to go thru it, or welding adjusting nuts onto the hitch, but it can be a remedy for your problem.
rockyrider
Reg. Jun 2004
Posted 2011-06-24 5:41 AM (#135095 - in reply to #135050)
100100100
Instead of a steel cap on truck bedrail, how about some rubber (like 1/2 thick stall mat). Since the trailer is older, I would look into attaching a rubber pad to both sides of it. Maybe with some velcro or glue. You may lose them over time due to weather but it's cheap enough to replace often.
rkranchgirl
Reg. Aug 2005
Posted 2011-06-24 10:15 AM (#135105 - in reply to #135050)
We had this problem on our old truck. We put blocks on the axles, the trailer sat level and didn't hit.
I guess I wouldn't do the steel cap idea. You never know where you might bring the trailer. I had to get in one spot and it did a pretty good job on the box, a plate would not have helped. And it seemed like I was just barely was hitting the truck...bent the box out.
