Eby Trailer front corner leaks
Last activity 2011-05-31 1:15 PM
6 replies, 6367 views
evallone
Reg. Jul 2004
Posted 2011-05-26 9:01 PM (#134368)
Subject: Eby Trailer front corner leaks
Hi folks its me (again).  Just finished today pulling out all the rotted paneling and insulation from a 2001 Eby living quarters I bought recently.  Front corners both leaked.  Before pulling it apart, I took it back to Eby and they recaulked the rivets and front corners pretty well.
I also have some very subtle mildew on the bottom trim wood of one side sliding window, but I can't find any caulking failures there.
So, my question - any clever ideas to help me avoid having this problem again?  Anybody else have this problem?  I had an Eby stock that leaked in the gooseneck, but I didn't care it wasn't finished.  I have a friend with an Eby dressing room and he took it back for leaks.
All ideas appreciated.
Happy trails ~~~
cutter99
Reg. Sep 2007
Posted 2011-05-27 3:21 PM (#134386 - in reply to #134368)
Subject: RE: Eby Trailer front corner leaks
10010010010025
Buy something other than an Eby! Plenty of other well made trailers out there that do not leak!!!
daafy
Reg. Apr 2006
Posted 2011-05-29 9:12 AM (#134406 - in reply to #134368)
I had a problem with leaks in the sleeping area of my gooseneck. I discovered that the drain "slits" on the outside frames of the windows were clogged, causing rain water to back up and spill  into the trailer.
Took a screw driver and cleaned out all of the dirt in the drains and problem fixed!
evallone
Reg. Jul 2004
Posted 2011-05-30 7:30 AM (#134413 - in reply to #134406)
Thanks so much that's a great idea.  I'll go check mine.
evallone
Reg. Jul 2004
Posted 2011-05-30 7:33 AM (#134414 - in reply to #134386)
Too late.  And, I knew it had the leaks when I bought it.  I can fix it and I saved maybe $15,000 ... worth fixing!
Posted 2011-05-31 9:56 AM (#134427 - in reply to #134368)
If it's made out of metal, your trailer can be fixed and sealed. It's just a matter of finding the leak (s)
Previous discussions:
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=15349
evallone
Reg. Jul 2004
Posted 2011-05-31 1:15 PM (#134439 - in reply to #134427)
Thanks!  Agreed.  That's why I bought it.  Can't wreck an aluminum trailer too easy!
